Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 03-21-2012, 11:17   #1 (permalink)
Member: 624694
Thanks Meter: 23
LT18i mic
i have a problem with sony lt18i
mic is not working
i removed the mic but still did not find any mic like it
so is there anyway to use another mic ?
Old 07-27-2012, 08:22   #2 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Same mic problem I change mic but still same mic not working any idea .....?
Old 01-01-2013, 20:20   #3 (permalink)
Member: 523680
same mic problem any one work on it .....!
Old 01-06-2013, 15:28   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
sony xperia arc s LT18 microphone
This handset has two microphone: premier and secondary
you did not explain where the broken mic
I help both microphonenya
secondary mic check his physical and L2852 and L2853
premier mic check his physical and L3502 and L3501 ... his mic mic bias in C9801
if the problem is the premier mic and check components
still either replace pcb mic premiere
see second picture below
Do not forget to press the thank
File Type: jpg sony xperia arc s LT18 mic copmponent.jpg (229.0 KB, 1042 views)
File Type: jpg sony xperia arc s LT18 microphone premier.jpg (59.8 KB, 924 views)
The Following 2 Users Say Thank You to d-Artigo For This Useful Post:
Old 07-31-2013, 10:43   #5 (permalink)
Member: 449561
Thanks Meter: 5
tnx...*** bless you .thankyou it worked
Old 08-31-2013, 08:49   #6 (permalink)
Member: 1707362
Sonork: ian torres
sir d-Artigo u have a LT18i board dead only i need value resistor coz i allready miss place the resistor pls help
Old 10-11-2013, 10:51   #7 (permalink)
Member: 1587126
thanks your sharing.....
Old 01-18-2015, 15:15   #8 (permalink)
Member: 1736815
Thanks Meter: 4
ye tu humko bhe pata hai
The Following User Says Thank You to sarwar.shah For This Useful Post:
Old 07-08-2016, 20:02   #9 (permalink)
Member: 2596004
Smile
thank you my friend
no mic for 3310 tone Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 14 12-30-2008 03:34
3310 no voice transmittion with working MIC rayes Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 04-17-2008 08:23
3310 then mic didnot work tone Nokia Hardware & Hardware Repair 4 04-03-2006 18:19
Siemens C30 mic no function. acyl2000 Siemens Hardware Repair Area 1 10-20-2002 03:48
3310 no mic Siemens man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-30-2001 23:15
Page generated in 0.19477 seconds with 10 queries
