thanks for the solution,but how if my x10 charging is fine but usb not detected when plugged into pc? i cant detect it, even in device manager. which part i had to fix? |
Or u have a more serious demage which I don`t think is fixable. |
thanks, so i just jumper this pinout right? seems in this guide different with mine, should i remove the ic (in red sign) or just solder the pinout of the ic into usb port pinout? there is also glue like in the picture. how could i remove this so i can solder it? any help please.. |
Just scratch it off. U can also heat it at about 250 degrees while removing it. They are not hard to remove anyway. Also I don`t know what u mean about ic? There is no ic u need to work with by this solution. |
In the first picture in red square, it seems an ic or smd component to me. So i just connect that two pin into usb port pin right? |
Hi guys, i'm having difficulties removing this glue part. It's seems solid and hard, i dont wanna break my board when removing this. http://i54.tinypic.com/20huhz4.jpg have any ideas? |
Nice sharing Hot Solution Thanxxxxxxxxxxxxxxxxxxxxxxxxxx |
Help... Quote:
i made this jumpers but when i conect it to PC, it say USB Device Not Recognized... :mad::mad::mad: any idea? or should i try this solution too? :confused::confused::confused: thx |
thanks for sharing sir.... |
thanks bro...........:D |
good job bro.keep it up. |
lazyyyyyyyyyyyyyyyyy solution |
tnx brother........................................... ...................... |
