Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
02-03-2016, 23:25 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: POLAND - UK Age: 41
Member: 293483 Status: Offline Thanks Meter: 43 | Sony Xperia Z5 Compact LCD issue FIX Hope it will be good for somebody else |
The Following 10 Users Say Thank You to blackangel82 For This Useful Post: |
08-23-2016, 00:20 | #3 (permalink) |
Insane Poster Join Date: Jul 2012 Location: paris, France
Member: 1780775 Status: Offline Sonork: 100.1651901 Thanks Meter: 19 | hello super man hi.........I am really greatful to you ;its awesome solution .I had the same problem now its ok ..........;But anyways I am gonna explain little bit about my problem . Actually at the beginning the backlight was on but no display . Unfortunately I tried to fix the problrm without disconnecting battery then something it may be fuse or register burn and then there was no light nothing , i thought the motherbaord dead . its new phone in the market so I was afraid but I just made jumper then it came to previous situation like bacllight on but no image in the display ..........Three days I tried without success but finally it iw working with your solution .............Thousands thanks to you |
09-26-2016, 11:34 | #6 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | Yes, do exactly the same jumper on this fuse near the LCD connector. Works! http://www.directupload.net/file/d/4...w9wqjc_jpg.htm |
The Following User Says Thank You to chimeto For This Useful Post: |
11-20-2016, 11:51 | #11 (permalink) |
Junior Member Join Date: Sep 2005
Member: 185048 Status: Offline Thanks Meter: 1 | I have a working Display but no backlight after screen replacement. For z3c the fuse was marked with a V according to some internet sources. Is it the par also marked with V on your photo? What should I let it replace with? Bridging would not be my preferred solution as it might have a function which apparently has already been used :-) Thank you very much! Florian |
11-21-2016, 20:42 | #13 (permalink) |
Member: 185048 Status: Offline Thanks Meter: 1 | Just took my 5€ multi meter and checked the two devices marked with L and V. While L gives me a resistance towards 0 ohm, V gives me infinite resistance. So apparently this is the fuse responsible for the backlight on Z5 Compact. Is there an exact replacement? Somewhere else I read that a 0 Ohm 63mA resistor would do the same job. Thanks Flo |
The Following User Says Thank You to smarty79 For This Useful Post: |
11-21-2016, 21:17 | #14 (permalink) |
Freak Poster Join Date: May 2008
Member: 777576 Status: Offline Thanks Meter: 32 | i am more interested in that one with "L". can it be replaced by some similar component from, for example an Z3 compact donor board, which i have here? i tryed first to brigde the L and A fuses, because no backlight and it worked, i got the screen back on, but then i noticed this issue: Fehler - Sendvid if the lcd is off, for few minutes, or longer, after i turn it on again, it shows those strange green issues for few seconds and then the green color disappears. the display is working normaly and those green issues are not showing again, while lcd is on. if i turn it off and leave the phone for 10 minutes again, when turning the lcd back on, green issue are there again. then i took V fuse from my Z3 compact donor board and replaced the brigde on the z5 compact board with it. no changes, i still had the green screen issue... then i took the second V fuse from Z3 compact board (the one for the vibra), replaced the other bridge with it (those one where originally the L fuse was). lcd and backlight still working, but i STILL have the green screen issue! now i am out of ideas... is maybe some other component faulty? or do i really need that L fuse, to get rid of those green "things" ? any help would be appreciated! |
