Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-12-2016, 17:50 | #5 (permalink) |
Freak Poster Join Date: Jul 2013 Location: CAIRO.EGYPT
Member: 1981679 Status: Offline Thanks Meter: 86 | Know and let people know this is called helpful koukou أرسلت من C6903 بإستخدام تاباتلك |
The Following User Says Thank You to ahmed koukou For This Useful Post: |
06-01-2016, 21:15 | #6 (permalink) |
Insane Poster Join Date: Jan 2006 Age: 40
Member: 222721 Status: Offline Thanks Meter: 0 | hello, can you please help? same problem, only red light, 3 red blinks when trying to turn on. first i tried other software solutions from another forum, no chance. then i tried hardware solutions. with the battery disconnected, and plugged the phone in charger. it showed on screen battery icon and charging for a few seconds and then it restarted. and nothing more. then i tried your solution but i think i made a mistake. the phone will not blink 3 times red when battery connected and trying power button like before. and with battery disconnected, charger connected, lcd lights up but nothing is shown on screen now. i don't know what to do |
06-01-2016, 22:16 | #7 (permalink) | |
Member: 1981679 Status: Offline Thanks Meter: 86 | Quote:
Can you provide me a pictures of motherboard and phone when it led up. Regards.AHMED KOUKOU أرسلت من C6903 بإستخدام تاباتلك | |
06-02-2016, 01:48 | #8 (permalink) |
Member: 1981679 Status: Offline Thanks Meter: 86 | Oops,disconnect battery tell you post the pictures. Do this fast as fast not damage the phone because it seems it is a short between gnd and vbat. أرسلت من C6903 بإستخدام تاباتلك |
06-02-2016, 23:20 | #10 (permalink) |
Member: 1981679 Status: Offline Thanks Meter: 86 | Hello, Upload pictures of your motherboard with jumper. Your phone now have a short circuit remove the jumper after take pictures. Regards, AHMED KOUKOU أرسلت من C6903 بإستخدام تاباتلك |
06-03-2016, 18:36 | #11 (permalink) |
Member: 222721 Status: Offline Thanks Meter: 0 | sorry for bad image. this is the best i could take with another phone at first try i didn't solder only the big contact, there was no connection with the small capacitor. i had the connection redone by a professional guy and this is how it looks now phone is not starting, when plugged in computer, pc companion recognizes the phone and gives me a message to disconnect and power on the phone but that doesn't help. also, when holding power and volume up, there is no reset, it does not vibrate 3 times i'm not sure why the image is not loading, here is the link http://imgur.com/RqMwwcd |
06-03-2016, 19:07 | #12 (permalink) |
Member: 222721 Status: Offline Thanks Meter: 0 | << more info >> when plugged in the computer, nothing happens for about 1 minute, after that the lcd backlight lights up, but without image and a blink of red led lights up behind the speaker. after this the pc tries to install MTP USB Device, another 3-4 seconds and the phone restarts and the process begins again... lcd backlight lighting up, no image on display, red led, driver install in pc the only way i can stop this process is to unplug the battery connector from the motherboard |
06-03-2016, 19:43 | #14 (permalink) |
Member: 222721 Status: Offline Thanks Meter: 0 | now it has been about 1 hour charging, still no response. with battery disconnected from motherboard i tried to flash a ftf file and flashtool did it's job very well. so the software can be changed. but still no response when trying to power on |
