Sonyerricson K220i No supported accessory problem(Charging problem). Brother please tell me how to solve Sonyerricson K220i "No supported accessory"(Charging problem) problem. :confused: |
you fully flash with infinity box your problem will solve |
yes mr krishna ia right i did the same 1 flash phone with repair ffs.. then do unlock charging problem solved and camera image is also saving here is the log [B]flash log[/B] COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active write: Firmware K200i_K220i_main_R1AB003_CXC1250822_En_Ru_Ee_Lt_Lv _Pl_Ua.80M.bin write: Flex/Customization K200i_flex_R1AB003_CXC1250822_CDA102773-48_R2A.80F.bin skip: Language Pack skip: FFS/File system skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 406250 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AD001 software version: CXC1250818 version flex: CDA102806/1 imei: 35243402401718 Check hardware done Read data ... reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-120855.80E.bin reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-120859.80E.bin reading Sony-Ericsson-K220i_35243402401718_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_ffs_20091106-121039.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:46237300000000 Write: Firmware Area: Flex/Customization flash: 01227E22212200:46237300000000 Write: Flex/Customization Write done Finished, time used: 618 sec Remove/Install battery now ! repair ffs log COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active skip: Firmware skip: Flex/Customization skip: Language Pack write: FFS/File system K220i_ffs_repair_default.80E.bin skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AD001 software version: CXC1250818 version flex: CDA102806/1 imei: 35243402401718 Check hardware done Read data ... reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-105337.80E.bin reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-105345.80E.bin reading Sony-Ericsson-K220i_35243402401718_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_ffs_20091106-105852.80E.bin Read data done Check data ... Check data done Write ... Area: FFS/File system flash: 01227E22212200:46237300000000 Write: FFS/File system Write done Finished, time used: 695 sec Remove/Install battery now ! unlock log COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AB003 software version: CXC1250822 version flex: CDA102773/48 imei: 35243402401718 Check hardware done Read data ... reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-1_20091106-123108.80E.bin reading Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K220i_35243402401718_eeprom_calibration-2_20091106-123110.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Write: eeprom flash: 01227E22212200:46237300000000 Write: eeprom .... .... .......... locks cleared Write done Finished, time used: 53 sec Remove/Install battery now ! regards! |
