Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 06-01-2009, 09:15   #1 (permalink)
ahmad5175's Avatar
Member: 246691
Thanks Meter: 54
k790i dead......help.......
i got k790i but i flash it to k800 no the fon become no network....but after that i try all solution about that problem nw my fon become cannot onn already?help..................................:con fused:if i check identify he show me this
v0.915035/UNI
CARD SERIAL: 00058104
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:101000000000000
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35220601059020 CERT:N/A
FLASH CID:49 COLOR:RED
IMEI MISMATCH ! GDFS IMEI:35220601088401
Model (from GDFS):K790i
Brand:Sony Ericsson
MAPP CXC article: R1CC003 prgCXC1250477_GENERIC_EV
MAPP CXC version: R1CC003
Language Package: S_ASIA_LEVAN
CDA article: CDA102568/110
CDA version: R4A
Default article: cxc1250491
Default version: R1CC003
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE NOT PRESENT
"R1CC003_CXC1250477_GENERIC_EV"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
Elapsed: 8 secs.
what the problem?i finish all solution that my buddy give me but nw the fon cannot switch on already help......................................:confuse d:
Old 06-01-2009, 09:17   #2 (permalink)
ahmad5175's Avatar
Member: 246691
Thanks Meter: 54
Open COM port OK
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
writing "C:\Documents and Settings\winxp_Service\Desktop\New Folder (7)\R1ED001_CHINA_fs.ssw.cry"
CURRENT FLASH FILE CID:49
SSW uses full hash, hash len is:4420
Will flash 221 blocks...
SSW loading returns:0
writing "C:\Documents and Settings\winxp_Service\Desktop\New Folder (7)\R1ED001_APAC_fs.ssw.cry"
SSW uses full hash, hash len is:4740
Will flash 237 blocks...
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
writing "tpa/preset/custom/C3_PCA_G3v2.cer"
writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm"
writing "tpa/preset/custom/customize.xml"
writing "tpa/preset/custom/DESKTOP_HOOK_2.itm"
writing "tpa/preset/custom/Entrust.net Root Certificate.cer"
writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt"
writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm"
writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm"
writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm"
writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm"
writing "tpa/preset/custom/GAMES_HOOK_3.itm"
writing "tpa/preset/custom/GTE_CyberTrust_Root.cer"
writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt"
writing "tpa/preset/custom/Root.cer"
writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt"
writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm"
writing "tpa/preset/custom/ThawtePremium.der"
writing "tpa/preset/custom/ThawteServerCA.cer"
writing "tpa/preset/custom/Utiroot.cer"
writing "tpa/preset/custom/VeriSignClass3Root.cer"
writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt"
Processing script "C:\Documents and Settings\winxp_Service\Desktop\readsecunits.txt".. .
Reading GDFS var 0002/0E5A
Reading GDFS var 0002/0E48
Reading GDFS var 0001/0851
Reading GDFS var 0000/0006
Reading GDFS var 0000/000E
Reading GDFS var 0000/0013
Reading GDFS var 0000/001C
Reading GDFS var 0000/0018
Reading GDFS var 0000/00AA
Phone detached
Elapsed: 543 secs.
Old 12-25-2009, 19:03   #3 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
i have same problam any body help me
Old 12-26-2009, 21:50   #4 (permalink)
Member: 755581
Thanks Meter: 567
repair gdfs can power on!
but no network 99% is hardware problem!
Old 12-27-2009, 06:34   #5 (permalink)
Crazy Poster
Member: 585212
Thanks Meter: 12
reflash with k790 file
k790i charging help! khan6653 Sony Ericsson Hardware Repair 1 11-06-2009 06:51
Need K790I EROM ,help! davilixian Cruiser Suite 4 10-14-2007 06:42
K790i unlock help ..::Sunil::.. Cruiser Suite 2 02-03-2007 13:29
Page generated in 0.17997 seconds with 9 queries
