Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-12-2010, 07:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 219450 Status: Offline Thanks Meter: 27 | w580 HDR block not accepted,error: 19 CARD SERIAL: 00125506 Loaded 51 flash descriptors CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):W580c MAPP CXC article: R8BE001 prgCXC1123476_CHINA_LA MAPP CXC version: R8BE001 Language Package: CHINA CDA article: CDA102568/1 CDA version: R2A Default article: cxc1123364 Default version: R8BE001 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R8BE001_CXC1123476_CHINA_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\New Folder\w850\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\New Folder\w850\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 14 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 6 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 5 secs. CFG:00000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 22 secs. SIGNED MODE (USING SERVER) CFG:10000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 33 secs. SIGNED MODE (USING SERVER) CFG:10000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\New Folder\w850\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:10000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 38 secs. SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35928501600116 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E writing "D:\New Folder\w850\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 14 secs. |
08-12-2010, 07:40 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | Quote:
choose the correct parameters, be sure that the restoration file must be present in the rest folder, cid should be the same, now correct the mistakes pointed by red color and do full flashing using signed mode........ wbr: sanjubhai. | |
08-12-2010, 10:08 | #4 (permalink) | |
wbr: sanjubhai. | |
08-12-2010, 10:11 | #5 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Phillipines
Member: 437090 Status: Offline Thanks Meter: 131 | Quote:
your flash cid is 52 you should flash it with cid 52 firmware not cid 49... your flashfile is cid 49 thats what error uccors.. | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
Nokia 5110 Blocked | Goodfox | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-18-1999 13:27 |
