Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 08-01-2008, 15:01   #1 (permalink)
Member: 770097
Thanks Meter: 9
Thumbs down w580 power on vibrator
hi all bro, i have w580 when power on just vibrator i tried to flash file but not get
Old 08-01-2008, 15:35   #2 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Try to reflash it and repair Gdfs and post the results remember to use different tools Eg se-tool and Mt-box before doing hardware.
Old 08-13-2008, 04:38   #3 (permalink)
Member: 770097
Thanks Meter: 9
hi all the brother i have k550i dad please helpe me
Old 08-13-2008, 04:54   #4 (permalink)
luqmaan751's Avatar
Member: 416940
Thanks Meter: 173
mostly the problem will be of gdfs failed. u have to repair gdfs through TP in setool bro
Old 08-13-2008, 05:55   #5 (permalink)
Member: 384098
Thanks Meter: 33
i have the same problem.b4 that my w580 problem is lcd no display,after i changed the upper ribbon then problem solved but suddenly got smoke come out from the bottom of board , the set become like that finally.once i press power on the phone vibrate like normal but lcd and keypad no light no respond.now trying to flash the phone....anyone got this experience?
Old 10-23-2008, 17:27   #6 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
i got same problem anybody sussed this one out
Old 02-18-2009, 10:56   #7 (permalink)
Member: 826316
Sonork: 9940673304
i am also have same problem please help me friends
Old 03-26-2009, 09:20   #8 (permalink)
ea12345's Avatar
Member: 130345
Thanks Meter: 10
any one have solution w580 only vib on its hardware problam no software.
Old 03-26-2009, 09:21   #9 (permalink)
ea12345's Avatar
Member: 130345
Thanks Meter: 10
still waiting ?????????????????????????????????????????????
Old 05-29-2009, 11:37   #10 (permalink)
Member: 384098
Thanks Meter: 33
write the correct gdfs.
Old 05-29-2009, 12:25   #11 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
yes ... its mostly gdfs problem
so write the correct gdfs via tp or supreme credit ...
and generally it happen when we do mistake by flashing w580i with w850i ...
so first now u identify it and see what model it show by gdfs ...
Old 07-10-2009, 19:00   #12 (permalink)
Member: 252178
Sonork: 100.1582561
Thanks Meter: 123
AFTER REPAIRE GDFS ALWAIS PHONE DEAD ONLY VEBRATE WHEN I TRY TO POWER ON
THIS IS LOG
  18:56:01  SE Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team
  18:56:01  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  18:56:01  Initializing...
! 18:56:01  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 18:56:01  2. Choose the phone model
! 18:56:01  3. Select the desired options
! 18:56:01  4. Please connect the phone either via USB while holding 2-5…
! 18:56:02  - or via a serial cable and double-click on it in the device list
  18:57:03  Selected phone: W580
  18:57:03  Connecting via Generic EMP USB Flash Device (USB1)…
  18:57:03  Device driver version: 1.1.0.12
  18:57:03  Device driver date: 9-25-2006
  18:57:04  Connecting to the baseband CPU...
  18:57:04  Entering baseband CPU service mode...
  18:57:04  Detected chipset: DB2020
  18:57:04  Boot mode: ROM
  18:57:04  Sending loader...
  18:57:04  IMEI: 35726502319319
  18:57:04  OTP CID: 51
  18:57:04  Effective CID: 52
  18:57:06  Please reconnect the phone (disconnect, connect while holding 2-5)
  18:57:15  Sending loader...
  18:57:16  Communicating with server…
! 18:57:22  News: Your credit consumption policy: Level 2 (Junior)
  18:57:23  Remainig credit (supreme): 2.11
  18:57:39  Remainig credit (supreme): 2.11
  18:57:42  Please reconnect the phone (disconnect, connect while holding 2-5)
  18:57:52  Sending loader...
  18:58:06  Initializing GDFS access...
  18:58:06  Writing GDFS…
  18:58:13  Code NCK for relock: 5479508366427325
  18:58:13  Code NSCK for relock: 8938657129725850
  18:58:14  Code SPCK for relock: 5184300811738033
  18:58:14  Code CCK for relock: 8648188526412356
  18:58:14  Code PCK for relock: 8176467282984617
  18:58:14  Code ESLCK for relock: 8331155769222980
  18:58:14  Code NCK for unlock: 1095487535452465
  18:58:14  Code NSCK for unlock: 0762706919988095
  18:58:14  Code SPCK for unlock: 3040305716151607
  18:58:14  Code CCK for unlock: 1213813214650267
  18:58:14  Code PCK for unlock: 2082457907718481
  18:58:14  Code ESLCK for unlock: 5204470370099415
  18:58:14  To enter a code, type < * * < on the phone with SIM-card inserted
  18:58:14  Writing flash…
  18:58:16  Turning off the phone...
  18:58:18  Done.
Old 07-11-2009, 17:36   #13 (permalink)
roro_manool's Avatar
Member: 192974
Sonork: 100.1627605
Thanks Meter: 495
there is no need to repair the GDFS . check the light ic or hinge
Old 07-12-2009, 09:39   #14 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
no need to repair gdfs for vibrate on power on.just flash in cruiser 100% sure.done many fones.
sajidmirza.
Old 07-27-2009, 08:59   #15 (permalink)
Member: 252178
Sonork: 100.1582561
Thanks Meter: 123
my probleme sloved whith change the flix
W580 Power on but blank screen bluehawk20 Sony Ericsson Hardware Repair 16 10-11-2011 07:31
w580 bluetooth not power on tando Sony Ericsson Hardware Repair 8 05-13-2010 04:37
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
3110c only vibrates on Power on ajubaba Nokia Hardware & Hardware Repair 1 06-27-2009 05:02
W580 no power, press power on the red light blinking! lamborghini Cruiser Suite 20 05-20-2009 07:31
Page generated in 0.23678 seconds with 9 queries
