W610i loader GDFS startup failed, that is fatal W610i loader GDFS startup failed, that is fatal http://i42.tinypic.com/9fuxqw.jpg Need help to solved this problem |
Repair gdfs problem solve |
How to repair plz tell me step by step |
if your w610 waz red blik you must change flash and do empty fiill operation or repair gdfs with tp or repair fhone with cruiser se ultimete unlocker logs |
loock here http://www.setool.net/video/index.php |
its possible to Universal Box |
hello, if u got dream box ,no need to change the flash ic ,only do test point . sure 10000% |
without remove ic impossibe to go test point b'coz test are back in IC any test point pic |
2 Attachment(s) hello , this is the test point pic, stage 1 is pin 2, stage 2 is pin 12 good luck!!! |
hello,all db2020 if red blink all can do with dream box , l have solve a lot for this . sure 10000000 % no need to change flash i/cu. ""u much use microscope "" |
