Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 09-06-2008, 06:08   #1 (permalink)
Member: 476772
Thanks Meter: 4
w850 can not on !!!!phoneID error (1) Error during phone id.
press identify
v0.914039/UNI
CARD SERIAL: 00033639
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35240101193393 CERT:N/A
phoneID error (1)
Elapsed: 3 secs.
press flash
v0.914039/UNI
Open COM port OK
Speed:921600
phoneID error (1)
Phone info read error !
Elapsed: 1 secs.
pls help me ?
what wrong with this handphone !!!!
what i need to do .....to solve this problem.....
Old 09-06-2008, 06:12   #2 (permalink)
Member: 718027
Thanks Meter: 32
try use USB cable to flash it..
The Following User Says Thank You to spinegy For This Useful Post:
Old 09-07-2008, 07:54   #3 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Originally Posted by TANGINGSIANG View Post
press identify
v0.914039/UNI
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
phoneID error (1)
Elapsed: 3 secs.
press flash
v0.914039/UNI
Open COM port OK
Speed:921600
phoneID error (1)
Elapsed: 1 secs.
pls help me ?
Last time when i have this error ( was on K610 ... ) the problem come from flash IC ( even i was try for fair play to resolder it, also to resolder DB2020 CPU ... but only change with new one revived it ) .
The Following User Says Thank You to debeliamark For This Useful Post:
Old 09-07-2008, 14:51   #4 (permalink)
Member: 476772
Thanks Meter: 4
i try dcu-60 cable , still can not ......mean flash .......
if i change flash ic , what should i do....before i change flash ic or after i change ????
Old 09-08-2008, 12:57   #5 (permalink)
Member: 718027
Thanks Meter: 32
after u change Flash IC , u need to do the Empty Board flashing 1st then only u flash the phone as normal flashing...
I need flash file w850 cid53 not on support area dharmdev DreamBox 0 10-31-2009 10:39
K800 On Proloader mode!!?phone can not on!! Wais777 SETool2 3 01-09-2009 18:34
30 times tp error finally its done Phone ID = 2380C373152094A4 SANGURAN_BOX DreamBox 1 09-08-2008 21:53
infinity box can not on tx lightt during flashing ghost__ Infinity-Box 3 09-13-2007 18:48
8310 can Flash but can not on mlngroup Nokia Hardware & Hardware Repair 3 09-21-2003 06:40
Page generated in 0.18938 seconds with 9 queries
