world first Sony Ericsson x10 charging solution 1 Attachment(s) hello hare is world first Sony Ericsson x10 charging solution with Picture i know there is so many friends having problem with x10 charging way so now problem solved |
Hi. Sorry my friend but you're not the first. Have a look at the post below:)) http://forum.gsmhosting.com/vbb/f261...n-hot-1127810/ |
I have already fixed about 50 phone and neved had a problem with ic. If the problem occurs, I would repalce the ic, rather than do a jumper - that's a professional attitude. Thanks for your point outs. Bye |
When you guys gonna learn how to appreciate ?? Doesn't matter who is World's First /// We are not giving Awards here. We are sharing solutions. LITTLE MASTER |
thanks for this picture , but allready repair charge without it , but maybe with this picture we can repair usb detect for update and unlock! maybe little master not have a big experience in gsmhosting,(ansari123 juin 2006 , little master jan 2010) he say not award, yes very thanks to all poster! to be continued thanks to ansari123 , continue like this ! best regard |
thankssssssssssssssssssssssssssssss a lot |
not workink brother ................ |
good solution thanks.............. |
what are you facing the problem may be i can help you about that |
Working fine for me .... i done more then 5 pcs .. just jumper the IC and that's it .. LITTLE MASTER |
hello all, I have one X10i, so the charge connecting is ok, but phone only power on when I put the charger in, and don't charge, so this can do from the IC ? and when I can find this IC pls ? Best Regards, JAVA Good. |
remove charging ic and make jumper as you seen on Picture theen reply |
for usb connection inverse blue wire with pink wire working usb tested |
