Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
05-11-2005, 19:27 | #8 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | Quote:
2.battery . 3.battery connector . 4.charger. 5.charging interface . 6.charging port area . 7. your power supply unit. 8.coupling phone problem. try this now. bestman space storage for pictures on my system is full . i will post you a close description on fuse near charging area. bestman Last edited by bestman; 05-12-2005 at 18:55. | |
05-12-2005, 07:59 | #9 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: mal Age: 46
Member: 117968 Status: Offline Thanks Meter: 27 | Quote:
05-12-2005, 08:26 | #10 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | Quote:
05-13-2005, 10:00 | #12 (permalink) | |
05-14-2005, 10:59 | #13 (permalink) | |
05-23-2005, 21:00 | #14 (permalink) |
Freak Poster Join Date: Aug 2003 Location: PORT HARCOURT,NIGERIA. Age: 54
Member: 36906 Status: Offline Thanks Meter: 1 | solution Z200 Hi guys,all you have to do is just to resolder all the components around the battery terminal.Their is just one major fuse that controls the charging(p07),close to the charging base,and two resistors on the pcb,only one of them (resistor)controls the charging with po7 fuse, if the two are okay just resolder all components,and phone should be okay. |
cect p168c not charge,low voltage 2,5v on battery pin solution? | nykocam | Chinese Models & Cloned Phones | 3 | 03-09-2010 07:56 |
z200 not charging,another z200 mic problem. | de brain box | Sony Ericsson Hardware Repair | 3 | 12-10-2007 09:31 |
Z200 not charging | ***GSM-LONI*** | Sony Ericsson Hardware Repair | 0 | 04-30-2005 14:41 |
z200 not charging | travolta | Sony Ericsson Hardware Repair | 10 | 10-18-2004 16:23 |
Z200 not charging | Cat10 | Sony Ericsson Hardware Repair | 2 | 09-30-2004 17:18 |
