GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Sony Ericsson Hardware Repair (https://forum.gsmhosting.com/vbb/f261/)
-   -   z3 d6633 no backlight after screen replacement (https://forum.gsmhosting.com/vbb/f261/z3-d6633-no-backlight-after-screen-replacement-1942010/)
makabress 04-25-2015 09:23
Hi
I have a z3 d6633 with full cracked screen and working backligh Only.
Replaced with new working screen (tested with d6603)
The phone, display and touchscreen work but no backlight
So trayed hard rest, and verified all fuse but find nothing
So any help are welcome
Thank you
makabress 04-25-2015 14:27
http://img11.hostingpics.net/thumbs/...9968155091.jpg
Find the solution by my self, now backlight work
Arkadi0o0 05-28-2015 13:25
z3 dual d6633 backlight very low
when backlight is very low same solution works i check it
blackangel82 07-08-2015 19:06
Hi what if back-light working but is no picture ?
luclang26 07-20-2015 16:58
schema sony z3 ? help me .
BIG-BERTA 08-17-2015 22:45
My Z3 is D6603 but my board is different from the one shown in the image. I cannot find the fuse, can anyone help me?
nara2005 08-22-2015 12:21
plz:rolleyes:
BIG-BERTA 09-19-2015 10:54
Someone please, new D6603 schema fuse?
Africano2006 04-04-2016 16:39
this solution is for z3 dual
brand_new_mike 05-07-2016 20:42
What about my problem...
I tried to replace the screen, ripped of flex, ordered new one, but for Xperia Z3 (not dual) by mistake, put that on and then realized it's a wrong one (when it did not work), got the correct one for dual sim, put that on, and the screen is not working. The phone seems to be working (vibration works when turning on, getting warm).
I've tried screens from eBay/Aliexpress. Maybe I should go for original Sony? But I really don't want to spend 100 pounds on it.
Would anyone have a working solution to this problem?
Gathering 05-24-2016 19:21
Hello, i need help, i changed lcd z3 but no backlight, i jumping the fuse and it work, but today doens´t work again, any idea? Or maybe a chip ou component?
Thanks a lot.
vagmix 05-30-2016 08:24
Did someone know if thiw works for the Z3 Compact (d5803)
kachalu 06-12-2016 14:34
it works for me, thank u,
adrs168 08-03-2016 15:10
Z3v d6708
Anyone has experienced to do in Z3V D6708?
Wondering where spotted of fuse to jumper in Z3V motherboard ?
Which Z3 type that has same motherboard with Z3V ?
Many thanks
Smoky_Eye 03-08-2017 13:22
Thanks a lot.
Jump is not solution, jump is only for testing
You have to put the new component on the pcb. You have something that shorts and fries the fuse. Check the backlight connection to LCD and cover it with kapton tape
Sent from my iPhone using Tapatalk
Page generated in 0.13705 seconds with 6 queries
