Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2012
Member: 1849962 Status: Offline Thanks Meter: 15 | z3 d6633 no backlight after screen replacement I have a z3 d6633 with full cracked screen and working backligh Only. Replaced with new working screen (tested with d6603) The phone, display and touchscreen work but no backlight So trayed hard rest, and verified all fuse but find nothing So any help are welcome Thank you |
![]() | #3 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Feb 2008 Location: Poland Gdańsk
Member: 713830 Status: Offline Sonork: 100.1656182 Thanks Meter: 28 | z3 dual d6633 backlight very low when backlight is very low same solution works i check it |
The Following User Says Thank You to Arkadi0o0 For This Useful Post: |
![]() | #10 (permalink) |
Junior Member Join Date: May 2016
Member: 2569950 Status: Offline Thanks Meter: 0 | What about my problem... I tried to replace the screen, ripped of flex, ordered new one, but for Xperia Z3 (not dual) by mistake, put that on and then realized it's a wrong one (when it did not work), got the correct one for dual sim, put that on, and the screen is not working. The phone seems to be working (vibration works when turning on, getting warm). I've tried screens from eBay/Aliexpress. Maybe I should go for original Sony? But I really don't want to spend 100 pounds on it. Would anyone have a working solution to this problem? |
![]() | #14 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2606982 Status: Offline Thanks Meter: 1 | Z3v d6708 Anyone has experienced to do in Z3V D6708? Wondering where spotted of fuse to jumper in Z3V motherboard ? Which Z3 type that has same motherboard with Z3V ? Many thanks |
![]() | #15 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2013
Member: 1921245 Status: Offline Thanks Meter: 43 | Quote:
Jump is not solution, jump is only for testing You have to put the new component on the pcb. You have something that shorts and fries the fuse. Check the backlight connection to LCD and cover it with kapton tape Sent from my iPhone using Tapatalk | |
