Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 10-28-2006, 13:34   #1 (permalink)
Member: 340551
Thanks Meter: 9
Z800i Not Charging. Help pls..
Domo Fuuuuuu~~~!!!!
Say! Say! Say! ~~~~
Hi everyone..
I got a Z800i which has a weird problem. When i plug in the charger, It seem charging... But the battery is always empty.
Any solution for this? Anyone?
Thanks in advanced.
Old 11-01-2006, 10:47   #2 (permalink)
Member: 340551
Thanks Meter: 9
No Solution yet?
Just bringing up Topic.
:P
Old 11-03-2006, 05:47   #3 (permalink)
Member: 340551
Thanks Meter: 9
Hello~~~
Is anyone here?
Old 11-04-2006, 12:30   #4 (permalink)
mobilesmith's Avatar
Member: 117968
Thanks Meter: 27
hi. there
do u found any components are burn or shorting when power up?
can tell me the current consumption value?
Old 11-04-2006, 12:46   #5 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
check this line & short
tested & work
Old 11-06-2006, 05:47   #6 (permalink)
Member: 340551
Thanks Meter: 9
Thanks for reply guys...
@mobilesmith
Nothing is burn... but the mobile is hot after On for few minute... suspect is the PA ic... cos there no network...
@Bourri GSM
I will try n post result
Oki
Old 11-06-2006, 16:41   #7 (permalink)
wizz25's Avatar
Member: 209093
Thanks Meter: 154
thinx RIADH.....
VERY GOOOODDD SLUTION
ye m3aaalleeemmm
the mobile is fine and full network....
Old 11-07-2006, 00:23   #8 (permalink)
wizz25's Avatar
Member: 209093
Thanks Meter: 154
@Bourri GSM...
the phone now charge by it self...
and a batterie.. quickly shut down...
Old 11-07-2006, 14:55   #9 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
there is another problem
the trick mùentioned before, is for not charging or power on by itself when u put charger (this solution to do not replace cristal charge IC)
maybe ur phone is water damaged
N500 not charging problem????pls help??? proxy_gsm VLSI, Conexant, Skyworks and Old Models 9 08-11-2013 17:56
Z800 Z800i not charging, please help wuhoo Sony Ericsson Hardware Repair 3 10-16-2010 07:45
3660 not charging help plz dj.comcell WD2 & APE (Symbian Phones) 0 03-29-2010 14:08
6030 not charging help pls. naim_007 Nokia Hardware & Hardware Repair 1 05-16-2009 07:40
z800i not charging baldovica Sony Ericsson Hardware Repair 0 07-31-2006 16:10
Page generated in 0.19401 seconds with 10 queries
