11-06-2007, 21:28 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 45
Member: 71874 Status: Offline Thanks Meter: 34 | Motorola V3x Criticial Error 00 My customer has tried to unlock the Motorola V3x himself and has messed it up. The handset is displaying: critical error 00 How can i restore this handset? I have tried using prepare mode but smartclip can't find the phone. Thanks Majid www.mobilekrazy.com |
11-07-2007, 08:16 | #4 (permalink) |
Member: 71874 Status: Offline Thanks Meter: 34 | Thanks i will use testpoint and repair the phone. To add more information to the first post; the customer used Motounlock and the log is detailed below: Establish connection to handset Switch handset to TCMD interface Switch handset to FLASH interface FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0682 Sending RAMDLD to handset RAMDLD started ok in handset Read flash backup from handset Finded jump address: 10003B8C Save flash backup Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0682 Sending RAMDLD to handset RAMDLD started ok in handset Set handset to blank mode Power down handset Establish connection to handset FLASH Interface established ok Read handset bootcore version Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Try to load backup file Write flash to handset Power down handset Set Blank Mode completed ok Establish connection to handset FLASH Interface established ok Bootcore version on handset: 0310 Sending RAMDLD to handset RAMDLD started ok in handset Started unlocking sequence Power down handset Unlocking sequence completed ok Establish connection to handset Error: 2020003 Error: 2020003 Error: 2020003 Error: 2020003 Error: 2020003 Thanks Majid www.mobilekrazy.com |
11-10-2007, 19:19 | #6 (permalink) |
Member: 71874 Status: Offline Thanks Meter: 34 | I have successfully resurrected the handset but now there is no signal. When you first turn the handset on the network shows for a few minutes and then disappears. How can i rectify this problem? Thanks Majid www.mobilekrazy.com |
11-12-2007, 10:02 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ bbmad, Check band settings, make sure that the handset support your network. You can try to update band settings using using SmartMoto. Also, one of possible reasons could be faulty antenna, make sure that it connected properly. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-12-2007, 20:57 | #8 (permalink) |
Member: 71874 Status: Offline Thanks Meter: 34 | Thanks for the reply. I have tried to update the band setting but this made no difference. I am currently inspecting possible hardware fault. Thanks Majid www.mobilekrazy.com |
12-02-2007, 17:43 | #9 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Gaming Zone Age: 43
Member: 202298 Status: Offline Thanks Meter: 35 | Problem not solved..... after that... why ????? I am facing same problem about critical error .... when i insert battery it show.... Critical Error... On the other hand. when i connect phone to smart clip for repair PDS.. it's show...this log... SmartMoto 2.46 S-Card: 8xxxxxxxx Smart-Clip dongle, v 1.52, assigned Smart-Clip: 9xxxxxxxx Europe, initializing... OK Clip serial: 9xxxxxxxx, version: 3.25, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... 0x90 - 0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 490,W510,Z3 Hardware IMEI: 5200FEF23D9E6F4 IMEI OTP status: locked Error: "Repair PDS" unavailable due to incomplete chip identification .................................................. ............ plz plz solve my problem and inform about correct solution.. waiting.................. farrukh. |
12-03-2007, 09:00 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ farrukh mobiles, Reading flash id... 0x90 - 0090, chip unidentified this error shows that the flash chip of the handset can not be read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Problem with V3X, Critical error 00 | ze4lous | Smart-Clip | 7 | 03-19-2010 08:14 |
V3x critical error 00 how to fix ? pls | ccipo | Ultima Box Light | 7 | 11-15-2007 12:25 |
Motorola V3x Unlock Error!!! | mint centre | Smart-Clip | 4 | 01-05-2007 01:40 |
Motorola E770v citical error 00 after unlock with P2K_Easy_Tool_v34 | Fys | Motorola P2K (USB-Smart) | 3 | 04-20-2006 12:52 |
