Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 06-18-2005, 14:52   #1 (permalink)
Member: 96632
E398 can not unlock with smartclip v2.14
i have four E398 flash no problem(good conenct with computer)
but can not unlock
may be new version have problem?
br
Old 06-18-2005, 14:54   #2 (permalink)
DeDo Gsm1911's Avatar
Member: 56038
Thanks Meter: 171
smart clip not support yet for higher boot loader of this phone and also not supported yet to c975 boot loader 6.3.0.1
B.R
Old 06-18-2005, 19:30   #3 (permalink)
Member: 105625
Thanks Meter: 44
Have you tried unlocking without battery?
Old 06-18-2005, 20:46   #4 (permalink)
Member: 96632
i try,but no OK,before update to V213,Smartclip can unlock E398,after update,can not unlock E398,why?
Old 06-23-2005, 21:08   #5 (permalink)
Member: 77227
Thanks Meter: 26
Hi. Did you tried without memory card inside. I just had same problem with brand new E398, not unlocked (with mem card), but tried again witout mem card and 100%.
Old 07-16-2005, 22:44   #6 (permalink)
Member: 79322
I have the same problem, my clip still 2.14. The e398 is boot loader 7.D0 and frim ware ver R372_G_0E.20.95R_A
Flex SE8609AXXJ804C - 2.0.H.3.2.2.0.15.0.0.1.
use power addapter for SC, connected fone to clip, pressed unlock. fone went to flash mode, clip green light blink 2 time then very dim green you can barly see it fo amost a minute then fone restart redlight come on SC, can not unlock, There was no flash card in fone, try with sim card and with out. Is there some thing i done wrong or did not do please advice, i need hlep.
Some one mention of flash it and then unlock it with SC, if so may i have the flash file or give me the correct file name.
Thanks guys
Old 07-18-2005, 10:55   #7 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 81,008
Why don't you update to 2.15?..
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 07-18-2005, 23:24   #8 (permalink)
Member: 79322
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Just did and my clip is dead, 4 hours later try to login but denied. Please help fix it, i am at the end here please so me the way out.
Copy of the log
SmartClip update software
Warning: make sure you use power adapter!
Windows LPT polling detected,
click "Advanced" for options
Clip serial: xxxxxx715
Firmware version: 2.15
login... OK
Server firmware version: 2.15
Checking clip... OK
EEPROM test successfull,reporting... done
update... 281pdate write failed
update try #2... 201pdate write failed
update try #3... 181pdate write failed
update try #4... 441pdate write failed
update try #5... 42
update write failed
Please help fast please!!
Think i got it fixed.
Thanks any way
Old 07-19-2005, 19:18   #9 (permalink)
Member: 79322
Still get red light while trying to unlock E398 after successfull updated to 2.15.
What is going on? why can it not able to unlock this fone is this not supported by SC?
Old 10-31-2005, 14:27   #10 (permalink)
cab
cab's Avatar
Member: 4262
me too can't unlock E398 with sw R372_G_0E.20.95R_A, I already updated my box to 2.17 HELP!!!!
Old 11-02-2005, 16:33   #11 (permalink)
Member: 121052
Sonork: 100.107126
Make sure you are not using a Forced boot mode cable...
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 12-20-2005, 18:07   #12 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
I'M NOT USING FORCE BUT CABLE, BUT i HAVE THE SAME PROBLEM.
Everithing seems vell, and at the end of the unlock process SC shows red light... My E398 is without SIM and flash card inside. I use power supply, SC v.2.18! What is the problem SC team?
TNX
Old 12-20-2005, 19:32   #13 (permalink)
trycktill's Avatar
Member: 208709
Thanks Meter: 31
update ur smart clip to newer verssion avalaivibale in suport area
Old 12-20-2005, 19:42   #14 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
well I have v 2.18, that is newest version....
Old 12-21-2005, 01:33   #15 (permalink)
Inovator's Avatar
Member: 144433
Thanks Meter: 49
I solved my problem with a bit flashing, and couple of hours of nervous breakdown's
V9 Not Unlock With Smartclip, Smartmoto All "ok" CCCS Smart-Clip 3 10-18-2008 21:48
Skyzen EZ700 Telcel not unlocked with mmodule v2.2 elcapitel Infinity-Box 7 06-07-2008 08:52
E65 can not unlock with Online Unlock helper_786 Universalbox 4 04-24-2008 13:47
PHILIP S660 CAN NOT UNLOCK with mmodule 1.45 jham Infinity-Box 2 04-26-2007 04:44
A31 can not unlock with Dreambox ivel-levi DreamBox 9 07-18-2006 04:56
Page generated in 0.21690 seconds with 10 queries
