03-22-2006, 19:18 | #1 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Poland / Germany
Member: 5076 Status: Offline Thanks Meter: 3 | E770 during unlock process error A0 now phone not work help!! I try to unlock a E770v during the unlock process i get this error message. Now Phone dont work only start up i see Vodafone logo and go off. i try to flash by RSD light but get also error any idea. Pleas help Best Regards *AnToS* Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 358012001445199 Security area saved to "S Blank Rainbow POG 358012001445199 (1).pds" Unlocking phone... error A0 |
03-22-2006, 19:38 | #2 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | Hello no i try to unlock the Phone again and i get this Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Sharp-0x00B0 (x2) Phone group: A835,A845,A920,A925 Internal error 0001 If i leave the Testpoint during unlock procedur i get Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 358012001445199 Security area saved to "S Blank Rainbow POG 358012001445199 (4).pds" Unlocking phone... error A0 Then i try to flash Bootloader from support selection i get this (with Tp connected, because if i disconnect TP afer Phone found with search i get Internal error 0001) Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 358012001445199 Security area saved to "S Blank Rainbow POG 358012001445199 (3).pds" Writing section0 10000/10000... 100% 87.2 Kb/sec sector write error Extended sector write error code is B000B0 hmm please help me now phone is totaly dead Thanks in advantage *AnToS* Last edited by AnToS; 03-22-2006 at 20:08. |
03-22-2006, 20:03 | #3 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | HI, Maybe PDS repair and than full flash fix this problem ??? but i have to leave the TP connected duing flash process because if i disconnect after Phone found i get Internal error 0001. hmmm very strange fullflash with Tp Maby someone from Smartclip team can give me a tip. Thanks *AnToS* |
03-23-2006, 08:38 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello AnToS, Error A0 probably means that Memory chip has a lose contact, apparently got damaged during removing the shield. Try reheating it with hot air, it should help. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-23-2006, 10:37 | #5 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | HI, hmm i dont remove metall shield i drill it very carefully. I dont think that a contact broken, but i will test it. Anyway i will try pds repair with full flash or it is not usefull ?? Best Regards. *AnToS* Last edited by AnToS; 03-23-2006 at 11:13. |
03-23-2006, 10:42 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | AnToS, You may try. And if it is software problem it should be sold! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-23-2006, 11:14 | #7 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | @ Mr.Tinkertrain What mean Internal error 0001. i get if i disconnect the Tp doing unlock process. First time i get this error also . Thanks in advantage *AnToS* |
03-23-2006, 11:20 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | As I see from your log files Internal error 0001 probably means that Flash chip got damaged. Try some hot air on it. It might improve connection of microchip. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-23-2006, 12:22 | #9 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
Connect cable, connect TP, Connect Battery, Press "Search Phone" and after this, disconnect TP. Now you can use unlock function. | |
03-23-2006, 12:48 | #10 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | Yes i know that i have to remove it. But i get only internal error also as the phone was working. So i read in Forum to leave TP connectet and it works but get error A0. So i will rehot the PCB and post results Ps. Is there any Sw version from E770v that is not supportet like X980 Phone? Thanks in advantage *AnToS* |
03-23-2006, 19:31 | #11 (permalink) |
Member: 5076 Status: Offline Thanks Meter: 3 | HI, now the phone is dead ;-((( after rehot the Flashchip "load error". I will use it for spare parts. I buy a new one Vodafone have this week spezial price 49 euro ;-) . Tomorror i will unlock the new one it is SW R252211_U_85[1].92.701P i will be sure if its supported via Tp?? Best Regards *AnToS* |
Please Help EM30 Dead during unlock process | Frix | Smart-Clip | 9 | 03-28-2011 07:30 |
N73 Keycode Count=4,set Off During Unlock Process | zonetrichur | UID - Box | 4 | 12-08-2007 17:36 |
L7-Weird behaviour during Unlocking Process | Peffram | GOT Motorola | 11 | 11-17-2007 11:57 |
Phone not working HELP | SERIES01 | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 12-02-2004 12:43 |
SONY CMD-C1 Unlock code on SmartDCT4Calc 2.18 not working. HELP Please | rioachim | Sony | 3 | 08-27-2004 22:39 |
