Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 12-20-2007, 14:32   #1 (permalink)
Member: 461767
Question F3 unlock error ... Sending boot...0xA007 failed
Old 12-20-2007, 18:12   #2 (permalink)
Member: 461767
SmartMoto 3.00
S-Card: ******** Smart-Clip dongle, v 2.00, assigned Smart-Clip: ****** Europe, initializing... OK
Waiting for the phone to power on...OK
I am using F3 USB cable from GSM server on-line, choose correct port, get the above error !
Can any one advise ....
Regards
Old 12-20-2007, 20:29   #3 (permalink)
elkawasmy's Avatar
Member: 113200
Sonork: 100.1573773
Thanks Meter: 87
make repair epprom then unlock it will be ok
tested many times
BR,
Elkawasmy
Old 12-21-2007, 08:30   #4 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ MohammedSharif,
This error usually appears when the cable wasn't connected properly.
Reattach the data cable and run unlock procedure once again.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 12-21-2007, 18:08   #5 (permalink)
Member: 337837
Thanks Meter: 537
Originally Posted by MohammedSharif View Post
SmartMoto 3.00
Regards
CHECK YOUR BATTERY,USE FULLY CHARGE BATTERY OR CHECK YOUR CABLE
Old 12-22-2007, 08:15   #6 (permalink)
cubafreak's Avatar
Member: 84130
Thanks Meter: 8
That error appears when using FTDI interface. Use serial inteface and all will be fine.
Old 12-22-2007, 11:36   #7 (permalink)
Member: 229997
Thanks Meter: 636
@ cubafreak,
Please install the latest version of SmartMoto and run unlock procedure once again.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
W205 Sending boot...0xA007 failed Nurettin Duman Smart-Clip 1 02-23-2010 08:18
Unlock w233 error .Sending boot ......... error nguyentung Smart-Clip 9 09-24-2009 07:56
W208 Sending boot...0xA007 failed F@RUK S Smart-Clip 26 10-12-2008 13:41
F3 and T250 same error Sending boot...0xA007 failed Leshy Smart-Clip 1 12-22-2007 07:52
W375 unlock problem,,,,sending boot,,,,failed steca Smart-Clip 14 05-26-2007 12:39
Page generated in 0.20543 seconds with 9 queries
