01-23-2006, 18:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 39
Member: 138926 Status: Offline Thanks Meter: 0 | Firmware not found, SC team help now i can't connect server. SmartClip update software 1.12 Warning: make sure you use power adapter! Clip serial: XXXXXXXXX Firmware not found login... failed to retrieve http status code http session failed, please restart application update... server is temporarily overloaded, try laterupdate cmd failed update try #2... update cmd failed update try #3... update cmd failed update try #4... update cmd failed update try #5... update cmd failed this is second time SmartClip update software 1.12 Warning: make sure you use power adapter! Clip serial: XXXXXXXX Firmware not found login... server is temporarily overloaded, try later this is third times(i change to another pc for update) SmartClip update software 1.12 Warning: make sure you use power adapter! Clip serial: XXXXXXXX Firmware not found login... denied Clip warranty period: 16-Jun-2005 to 13-Dec-2005 (expired) EEPROM test successfull,reporting... OK Update denied, save log and contact support help please. Last edited by fuzhiguo8888; 01-23-2006 at 20:49. |
01-23-2006, 19:11 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | don't panic freinds just try 2 or 3 times and you can update normally your boxes give server time to answer give it all the time he need and your boxes will be alive again good luck br <= The_Gorr => |
01-23-2006, 19:24 | #4 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
but no light in my box | |
01-23-2006, 19:30 | #5 (permalink) | |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | no light my freind mean no Firmware so just disconnect your box (no power / no LTP) power off your pc and power on (don't reboot) (because some LTP bugs can result to no light) and retray with update good luck br <= The_Gorr => and retray with update again Quote:
01-25-2006, 00:27 | #7 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: GSM network (near HLR) Age: 47
Member: 100920 Status: Offline Thanks Meter: 21 | nhooo!! now I have SC dead no light! ***UPDATE*** all problem solved after Quote:
)) Last edited by ackxxx; 01-25-2006 at 01:29. | |
01-25-2006, 17:10 | #9 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | my problem is still there SmartClip update software 1.12 Warning: make sure you use power adapter! Clip serial: xxxxxxxx Firmware version: 2.18 login... server is temporarily overloaded, try later Clip serial: xxxxxxxxx Firmware not found login... server is temporarily overloaded, try later Clip serial: xxxxxxxxx Firmware not found login... denied Clip warranty period: 20-Dec-2005 to 18-Jun-2006 (144 more days) EEPROM test successfull,reporting... OK Update denied, save log and contact support even send a log to smart clip team but no reply whatsoever br |
error Prtoection card not found! ET TEAM plz help | ezysuresh | ET-BoX | 6 | 01-15-2009 14:42 |
Yuo are not corect SC-team | fevrad | Smart-Clip | 1 | 01-06-2006 18:18 |
Firmware not found | yui | Smart-Clip | 14 | 12-29-2005 11:01 |
Firmware not found Help me | ligteltelecom | Smart-Clip | 4 | 08-22-2005 09:06 |
V980 Chaines firmware not found | maximusdecimus | Smart-Clip | 0 | 08-19-2005 15:38 |
