Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 10-13-2007, 11:08   #1 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
Thumbs up FOMA M702iG SUCCESSFULLY REVIVE BOOTMODE AND UNLOCK....
WE SUCCESSFULLY REVIVE BOOTMODE m702ig AND UNLOCK THIS PHONE VIA SMART CLIP....
HISTORY; WE ACCEPT THIS PHONE IN BOOTMODE already.
ACTION TAKEN; FLASH THE PHONE AND REVIVE to normal (we spend lots of time to research and study before return to normal mode after successfull revive, we unlock the phone.
MABUHAY ANG PILIPINAS!!!
-ALONG AND CORTS
Old 10-13-2007, 11:20   #2 (permalink)
Member: 226222
Thanks Meter: 2
@clearcom
please let me know the manufacture years and firmware version of M702iG which succeeded in UNLOCK.
I also tried several UNLOCK of M702iG.
The product made from December 2006 is O.K.
The product made from April and October 2007 is NG.
Old 10-13-2007, 11:22   #3 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
good work kababayan
br
Old 10-13-2007, 11:29   #4 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
Originally Posted by raezak View Post
good work kababayan
br
THANKS KABAYAN!!!
MORE POWER!!!
Old 10-13-2007, 11:56   #5 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
Originally Posted by tkhs1157 View Post
@clearcom
DEC. 2006............
Old 10-13-2007, 13:31   #6 (permalink)
Member: 226222
Thanks Meter: 2
Thank you
Since V2000_U_90.21.0C.B2I cannot UNLOCK, cautions are required.
Old 10-26-2007, 19:54   #7 (permalink)
Member: 556130
great on sim unlock, but what about branding? i have unlocked m702ig, but docomo firmware doesn't allow wap/mms settings. i can't even change the ringtone to my own mp4! how do we fix that?
Old 10-27-2007, 16:21   #8 (permalink)
vertz's Avatar
Member: 173878
Thanks Meter: 295
Thank you
look here mate, now it can be done... here's the log
SmartMoto 2.42
S-Card: xxxxxxxx Smart-Clip dongle, v 1.50, assigned Smart-Clip: xxxxxxxx Europe, initializing... OK
Clip serial: xxxxxxxx, version: 3.25, initializing... OK
Searching for phone... found FOMA M702iG, getting test interface... OK
Model M702iG
Firmware V2000_U_90.21.0C.B2I
Switching to flash mode... OK [S Flash Argon]
Reading phone boot version... 3.03
Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1CA30D0E44B65850.bk_
Processing data, 6 of 6 block...OK
Sending boot... OK
Erasing flash memory OK
Sending firmware OK
Searching for phone... found S Flash Argon
Searching for phone... no phone found
Reading phone boot version... 0.00
io timeout
Boot version 0x000 is not supported for model 'M702iG'
Searching for phone... found S Flash Argon, getting test interface... interface not found
Sending boot... OK
Sending firmware OK
Reading flash id... Intel - 28F256L18B
Reading flash id/2... Intel - 28F256L18T, OK
Phone group: K3,M702iG,V1100,V3xx,V6
Hardware IMEI: 35918200141xxx
IMEI OTP status: locked
Security area saved to "PDS for S Flash Argon 35918200141xxx.mbk"
Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1CA30D0E44B65850.bk_
Restore OK
Unlocking phone... OK
The Following User Says Thank You to vertz For This Useful Post:
Old 10-27-2007, 18:08   #9 (permalink)
Invisible's Avatar
Member: 3956
Sonork: galletto3 rules :D
Thanks Meter: 55
I also had one of that hp nx9010 laptops,
nice
best regards
Invisible
Old 11-06-2007, 13:17   #10 (permalink)
Member: 76770
could you share the flash file please? Today I unlock the same phone but stuck in bootloader mode.
Please...
Old 11-06-2007, 13:24   #11 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ bonsaiiii,
Flash files for this phone model can be found at boot-loader.com in PCF and MFW file sections.
To be able to flash this handset with *.mfw flsah file, Prepare Smart TestPoint cable should be used and "unlock automatically" should be marked off.
*.pcf files can be used by SCout flasher. Please check www.scoutdongle.com for more detailed information regarding SCout flasher.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post:
Old 11-06-2007, 19:40   #12 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Thats really great support from the Smart-Clip team
Old 11-07-2007, 11:01   #13 (permalink)
Crazy Poster
Member: 174886
I have problem Unlock M702iG load error
log here
SmartMoto 2.42
S-Card:............ Smart-Clip dongle, v 1.50, assigned Smart-Clip:.......... Europe, initializing... OK
Clip serial:............, version: 3.25, initializing... OK
Sending boot... OK
Sending firmware OK
load error
pls help me. Thanks Advance
Old 11-07-2007, 11:10   #14 (permalink)
Member: 229997
Thanks Meter: 636
@ thuanloivtnt,
Please tell us what cable you are using?
Where have you purchased it?
During Smart TP procedure, TestPoint should be hold until SmartMoto informs you to disconnect it.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 11-09-2007, 06:43   #15 (permalink)
Registered User
kenny81's Avatar
Member: 241148
Thanks Meter: 38
@ Mr.Tinkertrain
-I need driver S Flash Argon for flashing FOMA M702iG by Scout!
-I using cable Test Point of EM5 Company - China.
-But when unlocking M702iG still load error. I use only Primary Test Point A it is ok (I tested) but when i use both Test point A and B it not ok
LOG HERE
SmartMoto 2.42
Sending boot... OK
Sending firmware OK
load error
Pls help me! thanks advance
Foma m702ig successfully unlock Qaisar Mahmood Smart-Clip 2 09-27-2009 10:10
>>> Successfully repaired RPL and unlocked 6630 <<<< mujahid_ali BB5KING for (BB5BOX) 5 11-11-2008 22:50
unlock foma M702iG Success ............ .::LUQMAN::. Smart-Clip 10 09-17-2008 15:13
foma m702iG successfully sammy75 Smart-Clip 3 10-23-2007 07:16
FOMA M702iG Successfully Unlocked G i l l a n i Smart-Clip 1 10-22-2007 07:36
Page generated in 0.24685 seconds with 10 queries
