Help with E1 ROKR please. Hi, I've been reading all threads here about how to unlock E1 via testpoint, but still can't even get testpoint working properly. It took me 3 days now and only get "Searching for phone...no phone found" message displayed on Smart-moto. I'm using Smart-Moto V1.18 and SC v2.23 Here is all the steps that I did. 1. Disassemble phone. (Nothing attached only the circuit board) 2. Cut metal shield in order to get to testpoint 3. Connect Lpt port and charger to Smart-clip. 4. Connect USB to Smart-clip then to phone. 5. Open Smart-Moto. 6. Connect testpoint to ground using Test probe with Alligator clip at other end connect to a sheet of metal. 7. Connect battery. 8. Press "Search" button in Smart-Moto. Then nothing happened. Smart-Moto only showed "Searching for phone...no phone found" message. I also tried connecting battery before testpoint but wouldn't work out. I don't know what to do now. Please help me! |
sounds like either your testpoint isn't ground properly, make sure it's connected to sheet of metal on the phone itself and battery charged or connect to a 3v power source. |
connect to a sheet of metal ... sounds like u connect the tp to a seperate piece of metal ... ur procedure sounds perfect, just remember to connect the tp to PHONE's metal shield ... |
bro try to power the unit when you search the phone. and also replace your cable. use full charge battery or adoptor. |
Thank you for all replys. Problem solved!!! All I need is just connect tp to phone' metal shield. |
hi.. can someone please tell me how to do test point on a v551. i flashed it with wrong ******* pack and now it wont turn on. not even *+#+pwr works, that is i cant get into bootloader mode. i need something like... a guide... (if it had images would be perfect, but not entirely nessesary.. i know that's a lot to ask.) thanks in advance. |
1 Attachment(s) Have it.. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
wow thank you sooooo much for the image!! :D |
