04-01-2008, 04:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 481823 Status: Offline Thanks Meter: 0 | no smart clip dongle found cant find solution Well, my smart clip is new! i did everything to try to install, but for me it's impossible reinstall windows xp---> no smart clip dongle found reinstall drivers ---> no smart clip dongle found i install scard driver reboot pc conect smart clip and scard to pc (SC to lpt, SCARD to usb) go to update zone, but ALWAYS no smart clip dongle found i have already sent email to support but they don't give me a solution pls i think this is a harware problem i have already installed PortTalk, then try again but no success---> no smart clip dongle found i am from argentina i need a quick solution 'cause i have to work and i cant do it! so please help me with this or give me a new working box/dongle or wathever is damaged i think you are a G R E A T team, the best, you do the best, great updates, so don't dissapoint me, help me whit this SC, it is new! i've never used it! i'm so desespered! SmartClip update software 2.09 Warning: make sure you use power adapter! Clip serial: 584****** Firmware version: 1.24 login... OK Server firmware version 4.07 Clip warrany period: starts with the first firmware update EEPROM test succesfull, reporting... OK Checking dongle... failed No Smart-Clip dongle found Please connect dongle and try again Regards Mariano |
04-01-2008, 15:19 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ mario_e1, Please contact me in Private. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
04-02-2008, 13:21 | #9 (permalink) |
Junior Member Join Date: Sep 2007
Member: 594769 Status: Offline Thanks Meter: 1 | hey buddies help please :((:(( i'm very new to smart-clip can anyone help me my smart clip is not working at all i think i may do some mistake, whenever i try to update it i'm getting this error (checking dongle... failed.Smart clipt dongle not found. please connect dongle and try again. clip serial******* firmware version: 4.07 login...OK Server firmware version 4.07 Clip Warranty period: 24-Mar-2008 to 20-Sep-2008 (171 more days) EEPROM test Successfully reporting...OK) and when i try to open smart clip software from my PC, once i click on Search botton it says smart-clip not found if any one can help me i'll be very thankful of him i will appreaciate your help thank you in advance |
04-02-2008, 13:25 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ sohailba, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. LPT port settings are set to EPP in BIOS 3. Your LPT cable works properly 4. You use a stable power supply with your clip (use power adapter 12V 750mA) 5. If you are using WinXP, log in as Administrator or any other account with administrative rights 6. Reinstall drivers for the S-Card and restart your PC To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 04-02-2008 at 13:31. |
04-02-2008, 15:04 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mario_e1, Unfortunately your S-Card can not be repaired. It has to sent to us for replacement. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Smart clip not found with Smart adapter!!! | taihv | Smart-Clip | 15 | 10-01-2008 14:48 |
No any smart-clip dongle found | onlyweb | Smart-Clip | 18 | 04-01-2008 23:24 |
no smart-clip dongle found | kevin182029 | Smart-Clip | 1 | 03-23-2008 10:05 |
no smart clip dongle found | a2b2t | Smart-Clip | 2 | 12-19-2007 20:35 |
No any Smart-Clip dongle found | KhUSbCOMGSM | Smart-Clip | 4 | 03-21-2007 05:31 |
