Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 03-22-2006, 02:26   #1 (permalink)
Member: 216515
Thanks Meter: 4
How to make Testpoint USB Cables
Ive seen instructions for unlocking phones such as the ROKR without battery but i also want to know if theres a wire for the L7/v3x (mini-usb) cable that is compatible with the smart clip so we can unlock phones without battery. Can someone give me thorough instructions on making this:
Old 03-22-2006, 05:17   #2 (permalink)
Member: 216515
Thanks Meter: 4
Is this the dip switch needed? http://www.radioshack.com/product/in...entPage=search
How do you connect the switch to the cable and whats the procedure to instaling it on the cable?
Old 03-22-2006, 20:27   #3 (permalink)
Member: 138792
Just open the plug up and solder wherever you can! I did mine in a hurry, and i now have the plug with 2 wires hanging out of it which I twist together when I need the repair cable Crude but it works.
Old 03-22-2006, 20:55   #4 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
for the forced boot mode I use mini spst toggle switch and drilled hole in side of plug and put switch there (same as supplied with MSS4 and I cant see any reason why you cant have switch on either side. But dont know how to put on mini usb socket unless you just use the wire method as descibed and attach to cable with glue gun
Old 03-22-2006, 22:37   #5 (permalink)
Member: 216515
Thanks Meter: 4
Can someone link me to the switch and i need it to be able to unlock phones without testpoint not really need the boot mode. Someone take a picture of your REAL Cable so i can work off that and the instructions
Old 03-22-2006, 22:55   #6 (permalink)
Member: 138792
Well if you don't need boot mode what are you after this cable for?
Old 03-22-2006, 23:17   #7 (permalink)
Member: 216515
Thanks Meter: 4
Unlocking Motorola ROKR and others with the same port with the testpoint method without having a battery connected. Some forum members have confirmed it worked with the smart clip
Old 03-22-2006, 23:25   #8 (permalink)
Member: 67927
Thanks Meter: 101
you don't need to connect pins 13 and 14 then...
Old 03-23-2006, 00:13   #9 (permalink)
Member: 216515
Thanks Meter: 4
Pin 13 and 14 is for force boot mode the other pins are for the unlocking without a battery
Old 03-23-2006, 00:30   #10 (permalink)
Member: 67927
Thanks Meter: 101
for unlock new moto phones, pins 13 and 14 and not needed because phone will go to flash mode by it self when connecting tp....
Old 03-23-2006, 00:38   #11 (permalink)
Member: 216515
Thanks Meter: 4
Ok but still i want to mod the cable into a cable that powers the phone. For example with the cable i can unlock the Motorola ROKR without putting a battery and then i can see the testpoint clearly and i am able to unlock the rokr without a battery in place. The whole arangment of holding a battery and holding the testpoint and clicking in smartmoto requires you to have a few hands but when i unlock it by myself i use ruberbands to hold everything in place except to ground the testpoint so the battery almost covers the testpoint area and its hard to work. This cable would cut my unlocking time in 1/2. It only takes me about 30mins to do each testpoint phone
Old 03-23-2006, 00:49   #12 (permalink)
Member: 67927
Thanks Meter: 101
I understand what you are saying....
You don't have to connect pins 13&14, this is only good for old phones because phone will come on once you connect tp and power(either battery or cable)
Old 03-23-2006, 00:52   #13 (permalink)
Member: 216515
Thanks Meter: 4
oh ok didnt get what were you trying to say but i understand now
Old 03-23-2006, 08:37   #14 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
I cant see how it could work with the mini usb connector as the +v is already connected to charging pin unlike connector above
Old 03-23-2006, 17:29   #15 (permalink)
Member: 67927
Thanks Meter: 101
There is no solution for mini usb...
how to make modified usb cable and for NEC 338 sulai2k NEC 0 12-28-2009 09:36
How to make an USB cable to flash LG3 phones with Vygis? E&D LG 1 02-22-2006 11:03
How to make an usb cable to flsh c62 E&D NON Siemens Brand (ODM Phones) 8 02-17-2006 12:43
How to make a usb-cable for 902sh? schupa Sharp 4 06-12-2005 17:07
Any one know how to make 7650 USB cable Beginner WD2 & APE (Symbian Phones) 0 04-09-2003 03:29
Page generated in 0.40723 seconds with 8 queries
