Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 10-31-2007, 19:49   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Question J110i unlock ok...but phone still locked
I have a J110i SonyEricsson (locked on O2-Germany)that I tryed to unlock with SmartClip, I had used all the instruction provided on the supprt area all..ok...the program says unlock phone ok but phone still locked:when I put any sim cart in it says:Insert corect sim cart.
I am using the last update(v2.42);
Phone IMEI is ok;
I tryed even read codes option (after I used unlock option before) all codes are 12345678 with INACTIVE status...
What's wrong?????????????
Old 10-31-2007, 20:23   #2 (permalink)
Member: 131118
Thanks Meter: 40
it happend to my also
but solved my problem with infinity.
mayb SC dont support asll versions.
Old 10-31-2007, 20:38   #3 (permalink)
fs_djmellisse's Avatar
Member: 65093
Sonork: 100.1580654
Thanks Meter: 48
Phone IMEI is ok;
i have a same problem ....
i will try tomorow with infinity and post the result
Old 10-31-2007, 20:38   #4 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Thanks....but that's not a solution for me because I don't have Infinity....
At least there shoud be specifided on supprt what versions are supported...
Any replys from SmartClip Team??????????
Old 11-01-2007, 12:54   #5 (permalink)
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
Thanks Meter: 265
i try to unlock j110i with infinty.but Failed
COM2 [Serial1] selected
Device: Sony-Ericsson J110i
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
SW ver: 032H-000
HW ver: KIM-5-
Check Flash Done
Check Parameters...
file saved: backup_eeprom_ffs_20071101-034523.6AF.bin
Check Parameters Done
Check Space...
Flash: 0089:886200010001
flash: Intel 28F320W18-T T 4Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Writing Done
Finished, time used: 47 sec
Remove/Install battery now !
after Flashing Phone is Still Locked.
anyone Solve my problem.???
Old 11-01-2007, 13:39   #6 (permalink)
GSMSHOP1's Avatar
Member: 443140
Thanks Meter: 45
plz solve this problm
SmartClip
Old 11-01-2007, 15:33   #7 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,627
yes me to same prolem can't unlock J110i see her :
http://img126.imageshack.us/my.php?image=j110yp9.jpg
Old 11-01-2007, 20:44   #8 (permalink)
Member: 56523
Thanks Meter: 15
I have the same problem how dragosgsm.
Any solution from Smart Team??
Old 11-01-2007, 21:02   #9 (permalink)
steva's Avatar
Member: 4772
Thanks Meter: 556
And I have this problems too.My j110i after unlock all lock are closed.Why?
Old 11-01-2007, 21:02   #10 (permalink)
Member: 621936
Thanks Meter: 42
Action: reset
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
SW ver: 032H-000
HW ver: KIM-5-
Check Flash Done
Check Parameters...
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Writing Done
latest Infinity-Box software has "repair" button. You can flash repair eeprom and then press "repair" button and this procedure work for sure for any j110/j120 (tested by me several times and every time 100% repaied/unlocked phone)
as about smartclip unlock problem I can't say anything because I still cant update my smartclip/scar. but very first infinity-box version (several months back) j110 unlock software has some problems with unlock too but now all problem solved), probably smart-clip has the same problem (only several j110 phones can be unlocked but rest phones not possible to unlock).
Old 11-01-2007, 21:07   #11 (permalink)
Member: 621936
Thanks Meter: 42
Action: reset
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
Set Baud Done
Check Flash...
SW ver: 032H-000
HW ver: KIM-5-
Check Flash Done
Check Parameters...
Check Space...
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Writing Done
he-he-he.... I just see that you made "reset" procedure.... but you was wrong. You must press "Unlock" button in Infinity-Box but not "reset" and phone will be unlocked directly without any flashing
Old 11-01-2007, 21:23   #12 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Peoples,I posted this thread in SmartClip section not Ifinity....
SmartClip users need this problem solved by SmartClip Box not Ifinity!!!!!!!!!!!
After 2 days not even one oficial reply from SmartClip Team???????????...that not right...S.C. Team:WAKE UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-01-2007, 21:28   #13 (permalink)
Member: 245626
Thanks Meter: 21
MT-Box SE do it.
SC can't unlock it this time may be next update.
Old 11-01-2007, 21:42   #14 (permalink)
summer_20xx's Avatar
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
Agree with u, i have this same probleme too, waiting for SC solution
Old 11-02-2007, 00:36   #15 (permalink)
Cheater -Don't Deal with him-
Member: 172399
Thanks Meter: 203
Come On Sc Team Please Solve This Little Problem
And Fix It Too With K1 Dead With 0a.b4 Bl.
Cheers And **** Off
samsung t209 show unlock ok , but phone still locked, why and how to solve? svchost NSPRO 3 10-31-2009 13:09
unlock M600i cid49 with se pda unlock ok but phone still locked Haouas Cruiser Suite 2 12-18-2008 20:59
>>> CE110 unlock ok but phone still locked <<< keaelite FuriousGold 11 05-04-2008 19:51
1110i finished ok but phone still locked patric MT-BOX 3 12-24-2006 08:45
VG207 software says unlock ok! but phone still locked???? ReyTech Infinity-Box 2 12-12-2006 09:26
Page generated in 0.24641 seconds with 9 queries
