M702iG unlocking error please help..... here is the log... i try unlock moto M702iG.... SmartMoto 3.04 S-Card: ********* Smart-Clip dongle, v 2.01, assigned Smart-Clip: ******xx Europe, initializing... OK Clip serial: ******xx, version: 4.01, initializing... OK Searching for phone... no phone found Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.03 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F256L18T, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 359182000660*** IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 359182000660*** (8).mbk" Unlocking phone... error 9B ---- unlocking ERROR!!!!! Turning phone off... OK i try prepare phone without "check" the unlock automatically after prepare... Searching for phone... no phone found Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.03 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F256L18T, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 359182000660756 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 359182000660*** (9).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (68.4 Kb/sec) Turning phone off... OK Flash completed! phone flash completed but when i turn on vibrating and keypad light only... |
@ carlluvjo, Please tell us what firmware version your handset originally had and what flash file have you used to flash it? http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
