10-27-2007, 15:46 | #1 (permalink) |
Junior Member Join Date: Mar 2003 Location: CS
Member: 24491 Status: Offline Thanks Meter: 1 | W510 Critical Error DEDE 00AD Now when put the batery in phone display "Critical Error DEDE 00AA", and the Smart Moto o Scout not detect the phone, say "phone not conected", then I can't tray to unlock it. What can I do for solve this? Thank you very much. By ROS. |
10-29-2007, 09:32 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ros_GSM, Please tell us what cable have you used for unlock procedure. Where have you purchased it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-29-2007, 12:03 | #3 (permalink) |
Insane Poster Join Date: Nov 2003 Location: Brasov,ROMANIA Age: 56
Member: 45234 Status: Offline Thanks Meter: 28 | with this cable i unlocked 3 phones....no cable problem... now...smart clip not recognize phone and display apear CRITICAL ERROR DEDE 00AD b.r. liviugsm |
10-29-2007, 14:23 | #6 (permalink) |
Member: 24491 Status: Offline Thanks Meter: 1 | @ Mr.Tinkertrain Thanks for reply, I purchased the cable to my reseller, and he told me that de cable its ok. I've the same problem that gsmservice, smart clip not recognize the phone, then I can't do it nothing for unlock, flash or revive the phone. :-( Best Regards. By ROS. |
10-30-2007, 10:00 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ros_GSM, One of possible reasons for such problem is some hardware malfunction, please check the mainboard of the phone. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-07-2007, 15:26 | #8 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 41
Member: 84130 Status: Offline Thanks Meter: 8 | I've the same problem and the phone has not hardware malfunction. I unlocked many v3xx, V3re and W510 with my cbale so no cable problem. The phone was detected many times until this problem, now SC can't detect it. |
11-07-2007, 19:50 | #9 (permalink) |
Member: 24491 Status: Offline Thanks Meter: 1 | I still have with the same problem: the smartmoto, scout and rsd programs not recognize the telephone; so I can't try to repair it. Can anybody help me, please? Thanks a lot. By ROS. |
11-08-2007, 00:52 | #10 (permalink) |
Member: 24491 Status: Offline Thanks Meter: 1 | Now, I do a normal TP from TP-A to GND (not smartTP) and smartmoto detect phone as a Black Neptune, but when I try to prepare phone, repair pds, flash,... it show me errors, and the phone still dead. This is a log with the errors: SmartMoto 2.42 S-Card: 3237xxxxx Smart-Clip dongle, v 1.50, assigned Smart-Clip: 9333xxxxx Europe, initializing... OK Clip serial: 9333xxxxx, version: 3.25, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'W510' error 80 io timeout Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Thanks By ROS. |
11-08-2007, 08:29 | #11 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Ros_GSM, Quote:
In this case the phone needs hardware repair. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
11-08-2007, 20:24 | #13 (permalink) |
Member: 45234 Status: Offline Thanks Meter: 28 | Too many w510 death.Maybe it's a bug on phone or bug to smartclip prog. Unlock succesfull 10 pcs w510 and no error.but....but 2 pcd is death.... SMART TEST POINT IS USING ONLY TO UNLOCK PHONE.....NOT TO A PHONE INFO AND PREPARE PHONE Maybe tp short to (+)....BE CAREFULY.... see photo HERE IS SOME ERRROR: Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'W510' error 80 Reading data..failed Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'W510' error 80 io timeout Searching for phone... no phone found Connect phone to Smart-Clip before proceeding Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed B.R. LIVIUGSM Last edited by gsmservice_is; 11-08-2007 at 20:34. |
12-14-2007, 19:33 | #14 (permalink) |
Junior Member Join Date: Jun 2005 Location: Parana - Brail Age: 51
Member: 155543 Status: Offline Thanks Meter: 1 | W510 Critical Error DEDE 00AD I used procedure described by friend "gsmservice_is" and anyway my W510, but still not reading anything ... Does not recognize the smart clip or not for a USB cable ... Completely without any signal. Some another hint? |
12-26-2007, 21:10 | #15 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Pluto Age: 43
Member: 135688 Status: Offline Thanks Meter: 1 | please whatb can i do? w510 dead but still connect to smart moto, but can't preapere or unlock always says this message, but i have backup the file before the phone stop working SmartMoto 3.01 S-Card: ********* Smart-Clip dongle, v 2.00, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: *********, version: 4.00, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot version 0x400 is not supported for model 'W510,W490' Boot version 0x400 is not supported for model 'W510,W490' please help me bigdada |
The Following User Says Thank You to bigdada For This Useful Post: |
L7i; Critical Error DEDE 00AD | ru_dee | Motorola P2k | 1 | 10-05-2009 13:20 |
w510 CRITICAL ERROR 0085 00CA | cmartinezsv | Smart-Clip | 18 | 03-06-2009 13:40 |
another W510 Critical Error DEDE 00AD | gsmservice_is | Smart-Clip | 15 | 11-23-2007 17:15 |
Critical error[1207] | TATARIN | Infinity-Box | 14 | 05-30-2005 20:27 |
Always geting the critical error! | Corban | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-26-2002 10:27 |
