09-06-2009, 06:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Motorola V3T successfull unlocked boot loader 0A.52 & complete help Follow the instructions: Boot loader 0A.52 is supported to unlock via test point and individual test point for V3T is not available this time but V3i and V3r test points are same to V3T for bootloader 0A.52. see below http://i583.photobucket.com/albums/s...jabbar/V3r.jpg http://i583.photobucket.com/albums/s...jabbar/V3i.jpg Disassemble phone - see pcb structure and wich is same one of them - connect test point - connect pcb to smart clip via usb cable - click on search button phone will be detected "found S Blank Neptune LTE2" mode - select V3T from unlock option - now disconnect test point - click on unlock via test point all will be ok see log below: SmartMoto 3.23 S-Card: 60174xxxx Smart-Clip dongle, v 2.12, assigned Smart-Clip: 31719xxxx Europe, initializing... OK Clip serial: 31719xxxx, version: 4.09, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 35301401202xxxx IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 35301401202xxxx.mbk" Unlocking phone... OK http://i583.photobucket.com/albums/s...untitled-2.jpg mianlinks |
The Following 7 Users Say Thank You to mianjabbar For This Useful Post: |
12-04-2009, 12:43 | #2 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 436948 Status: Offline Thanks Meter: 4 | I Tested V3t Its ok SmartMoto 3.23 S-Card: 30******** Smart-Clip dongle, v 2.12, assigned Smart-Clip: 93********Europe, initializing... OK Clip serial: 93********, version: 4.09, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 353******** IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 353013017690559 (1).mbk" Unlocking phone... OK Thanks Smart-clip |
07-16-2020, 15:19 | #4 (permalink) |
Freak Poster Join Date: Jun 2003 Location: FLA, US Age: 47
Member: 31969 Status: Offline Thanks Meter: 13 | I've got everything together SmartMoto 4.33, V3T 0A.30, after disconnecting test point and pushing "Unlock via TestPoint" I get: Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Boot prepare... The smart card state is 'removed' What does this mean? |
08-27-2020, 12:30 | #6 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,312 | Quote:
Discontinued | |
10-14-2020, 00:23 | #7 (permalink) | |
Member: 31969 Status: Offline Thanks Meter: 13 | Quote:
How to unlock V3 with boot loader 0A.52??? | svchost | Smart-Clip | 19 | 06-04-2009 09:50 |
Boot Loader 0A.52 v3rohs unlock problem | sc0n3x | Ultima Box Light | 8 | 07-25-2007 10:34 |
V3T unlocking Boot Loader 0A.52. how | FullFlash2007 | Smart-Clip | 7 | 03-09-2007 12:20 |
Unlock V3rhos Boot Loader 0a.52 | aikonmani | Motorola P2k | 0 | 02-13-2007 09:50 |
V3i With Boot Loader 0A.52 | phanthom2o4o | Smart-Clip | 1 | 12-23-2006 10:18 |
