12-30-2005, 04:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 92326 Status: Offline Thanks Meter: 205 | ROCKER E1 itunezzzzzzz open your brains instead ...bla bla bla in forum Clip serial: XXXXXXXXX, version: 2.20, initializing... OK Searching for phone... found Motorola Phone (E1 iTunes iTunes), getting test interface... OK Model E1 iTunes Firmware R373_G_0E.30.42R Reading info OK Switching to flash mode... OK Reading phone boot version... 2.00 Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V190,V330,V53x,V54x,V55x ,V62x,V635,V80 Hardware IMEI: 35687500XXXXXX Security area saved to "S Blank Neptune LTE 356875001887830.pds" Writing section0 done Turning phone off... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK Unlocking phone... OK enjoy a happy new year sm4rtboy |
The Following User Says Thank You to SM4RTBOY For This Useful Post: |
12-30-2005, 21:48 | #3 (permalink) |
No Life Poster Join Date: Mar 2005
Member: 127049 Status: Offline Thanks Meter: 49 | I saw three place SM4RTBOY post the same infor,,but you ask him XP or step by step,,he doesn't answer,,,may be he kept secret for himself we need to know what display when he get *-#-power,, hihihihiih double check BRAIN |
12-31-2005, 00:29 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | I can do it now as well !! but i can't really know what is the correct steps .. because I just do it in many ways, and finally worked!! and, the step from the Smart-Moto site is INCORRECT!! |
12-31-2005, 04:22 | #5 (permalink) | |
No Life Poster Join Date: Dec 2003
Member: 47384 Status: Offline Thanks Meter: 8 | Quote:
I THINK PEOPLE HAVE A PROBLEM IS ATTACH BATTERY AND POWER MY WAY MAY HELP YOU AND OTHER GOOD LUCK | |
12-31-2005, 04:30 | #6 (permalink) |
Member: 92326 Status: Offline Thanks Meter: 205 | THE SECRET IS : phone ON , battery attached..than ~make TP and ..unlock via smartmoto at same time !.. after that unlock again (here) no TP required at end session .. ...you need practice first ....hahahahahahahah enjoy..and ~ ( ' . ' + ' + Happy New Year' * * ' . ' . + ' ' . ' . ' . + . ' . * ' ' sm4rtboy |
12-31-2005, 23:05 | #8 (permalink) |
Member: 127049 Status: Offline Thanks Meter: 49 | these all I get,,,I try so many ways my phone :Bootloader :0A.02 version : R373_G_0E.30.34R_A Cingular I try 3 hours not working at all some one know What am I did wrong ? help me to try again Clip serial: XXXXXXXX, version: 2.20, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... 0x0090-0x0090 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 67A67EEE0F9F8F5 Security area saved to "S Blank Neptune LTE 67A67EEE0F9F8F5.pds" Searching for phone... no phone found Searching for phone... no phone found Clip serial: XXXXXXXX, version: 2.20, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Reading phone boot version... io timeout Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... 0x0090-0x0090 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 67A67EEE0F9F8F5 Security area saved to "S Blank Neptune LTE 67A67EEE0F9F8F5 (1).pds" Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V190,V330,V53x,V54x,V55x ,V62x,V635,V80 Hardware IMEI: 356389002129176 Security area saved to "S Blank Neptune LTE 356389002129176.pds" Testpoint unlock not supported for this boot version Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... 0x0090-0x0090 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 67A67EEE0F9F8F5 Security area saved to "S Blank Neptune LTE 67A67EEE0F9F8F5 (2).pds" Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... 0x0090-0x0090 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 67A67EEE0F9F8F5 Security area saved to "S Blank Neptune LTE 67A67EEE0F9F8F5 (3).pds" Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V190,V330,V53x,V54x,V55x ,V62x,V635,V80 Hardware IMEI: 356389002129176 Security area saved to "S Blank Neptune LTE 356389002129176 (1).pds" Testpoint unlock not supported for this boot version Searching for phone... no phone found Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... no phone found Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... no phone found Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... OK Model E790 Firmware R373_G_0E.30.34R_A Reading info OK Searching for phone... found Motorola Phone (E790 iTunes), getting test interface... OK Model E790 Firmware R373_G_0E.30.34R_A Reading info OK |
12-31-2005, 23:15 | #9 (permalink) |
Member: 127049 Status: Offline Thanks Meter: 49 | Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... Intel-28F256L18B Phone group: A630,E1,E37x,E39x,E55x,V3,V190,V330,V53x,V54x,V55x ,V62x,V635,V80 Hardware IMEI: 356389002129176 Security area saved to "S Blank Neptune LTE 356389002129176 (1).pds" Testpoint unlock not supported for this boot version some time it says not compatibel chip to write/flash |
12-31-2005, 23:22 | #10 (permalink) |
Member: 127049 Status: Offline Thanks Meter: 49 | thank SMARTBOY thank you my friend I really don't understand,,,,,,what you say,,,, IF YOU KNOW ,can you step by step,,,you just say few words no time,no when,no where,,you don't want go to the point to finish job , if you check all my post : if I know I post step by step,,,, HAPPY NEW YEAR |
01-01-2006, 07:44 | #11 (permalink) | |
you may need to share my special cable and then you don't need to use battery to unlock E1 BACAUSE USE BATTERY TO UNLOCK E1 VERY HARD TO DO Have a good one | |
01-03-2006, 00:05 | #12 (permalink) | |
Member: 92326 Status: Offline Thanks Meter: 205 | Quote:
try Old School... br sm4rtboy | |
01-03-2006, 01:08 | #13 (permalink) | |
are u sure? | |
01-03-2006, 01:20 | #14 (permalink) | |
Rocker E1 can be done imxx | foxmir | MSS Box II | 0 | 10-20-2008 13:38 |
Help E1 Rocker | polizeirc | Ultima Box Light | 4 | 08-30-2008 10:20 |
E1 Version E1 (r373_g) - 0a02 | kaspersk | Ultima Box Light | 3 | 07-08-2007 04:38 |
E1 Rocker Original | gsm_school_indo | Motorola P2k | 0 | 01-28-2007 16:18 |
E398@e1 = Ok, E1@e398 = ???? | Cryspim | Motorola P2k | 0 | 11-10-2006 23:55 |
