09-27-2005, 16:20 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 39870 Status: Offline Thanks Meter: 0 | V980 unlock problem!! Searching for phone... found Motorola Phone (V980M), getting test interface... AT command error Clip serial: *********, version: 2.15, initializing... OK Searching for phone... found Motorola Phone (V980M), getting test interface... AT command error This error is possible during phone turning on, you may try <Search> once again pls help on this matter so i can seewhere could i be going wrong kind regards Tony |
09-28-2005, 11:55 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try to perform a master reset & master clear from the phone's menu.. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
09-28-2005, 12:37 | #5 (permalink) |
Member: 39870 Status: Offline Thanks Meter: 0 | All sorted, yer man had his phone lock on the handset , so just took that off and worked fine. Well at least we know that having a phone lock on wont allow you to unlock it!!! Thanks guys Regards Tony |
12-07-2005, 20:00 | #6 (permalink) |
Freak Poster Join Date: Apr 2005 Location: China Macedonia Germany Age: 42
Member: 136800 Status: Offline Thanks Meter: 26 | unlock problem Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... clip communication failed Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... clip communication failed Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F1 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 355603xxxxxxxx Security area saved to "S Flash Rainbow POG 35560xxxxxxx (8).pds" Writing section0 boot done Writing section1 done Flash completed! connecting to server... cannot connect to the server |
12-07-2005, 20:01 | #7 (permalink) |
Member: 136800 Status: Offline Thanks Meter: 26 | unlock/flesh problem help smart clip Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... clip communication failed Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... clip communication failed Clip serial: xxxxxxx, version: 2.18, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 5.F1 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 355603xxxxxxxx Security area saved to "S Flash Rainbow POG 35560xxxxxxx (8).pds" Writing section0 boot done Writing section1 done Flash completed! connecting to server... cannot connect to the server |
12-16-2005, 14:46 | #8 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: Bosnia and Hercegovina @ Saraj Age: 40
Member: 45907 Status: Offline Thanks Meter: 8 | Quote:
maybe firewall is blockinf smart moto to access internet | |
v980 unlocking problem | paklink | Smart-Clip | 6 | 12-29-2006 18:18 |
v980 unlock problem with smart clip-moto!! | mmanduri | Motorola P2k | 6 | 02-21-2006 22:24 |
v980 unlock problem | zata222 | Smart-Clip | 5 | 01-11-2006 20:40 |
V980 unlock problem | microera | Smart-Clip | 1 | 12-27-2005 16:54 |
V980 unlock problem | The_Gorr | Smart-Clip | 1 | 12-19-2005 12:21 |
