Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 04-15-2005, 21:29   #1 (permalink)
hmotwr's Avatar
Member: 137582
Thanks Meter: 93
Need help on v180 unlocking
I tried everything, Turned off the phone, then press unlock button on smart-clip, and press power on the phone. Then I tried with the phone on, and with the charger conected, used all combinations and the TX led turned on always, but then te e/g led turned on red always. I used c115 cable.
I'm running on 2.10 firmware version.
Send me your e-mail if you want the flash file to analize it.
Old 04-18-2005, 08:22   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,847
Mainly check your cable, make sure it has the same pinout as it shown on the scheme at http://www.smart-clip.com/pinout_p2k_to_usb.pdf (Motorla P2K to USB A standard cable)
And just to remind you all steps to be done.
Power on the Smart-Clip and E/G indicator will light green.
Power on the phone without SIM card and flash card (if present).
Connect phone to Smart-Clip and press the "Unlock" button ( red on older clips ).
E/G indicator will light green and go off, the phone will switch off (some models will automatically turn on then).
E/G will light green on success or red on error
Successful unlock resets User Code to 1234, Security Code to 000000
Unlocking newer versions of V18x/V22x/C65x/C38x or C975/V980/E1000 (Boot Loader 0.6.1.2) may require additional user intervention.
It may happen that E/G led still blinks after display turns off - it means that you have to turn the phone ON manually within 2-3 seconds after display turns off; alternatively you can try to unlock this newer version of V18x/V22x/C65x/C38x with battery charger on.
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Pls i need help on n96 unlocking with v2.02 shola5 BB5KING 17 09-09-2009 01:14
Need help on seultimate unlocker derrytea Cruiser Suite 3 02-11-2009 11:51
Need Help On Buying Unlocking Box Jaff Vs Ufs JOKERS Nokia Digital Core Technology 4 ( DCT-4 ) 3 03-17-2008 15:10
Need help with V180 Unlock/Repair Acer@Work Smart-Clip 2 08-18-2006 16:01
Need help!!! Mot V180 ABCom Motorola P2k 0 03-31-2005 20:33
Page generated in 0.13253 seconds with 9 queries
