06-25-2008, 16:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | <<<<<please help me ... V3xx >>>>>> Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 3530********** IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 35302201******.mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (92.7 Kb/sec) Flash completed! my phone still show boot-loader Thanks.. |
06-26-2008, 01:45 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi Why was phone connected in bootloader mode? ..Searching for phone... found S Flash Argon? Do what SmartMoto tells you..To get phone to work, you should write flash into the phone Reflash with SCout, and all is well....not to worry! Download your flash from boot-loader MAKE SURE to select your flash file from the correct phone group (Typical or Untypical), and a flash version equal to or higher that the handset currently has. Good luck! ;smokin |
a1 team please help me v3xx unlock | cellcarekphb | A1-Services.org | 0 | 06-02-2009 16:26 |
please help me....V3xx | karikari | Smart-Clip | 1 | 06-17-2008 13:47 |
plz help me v3xx dead after flash with scout | abcrino50 | Scout | 3 | 10-30-2007 00:12 |
