Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 05-06-2007, 04:33   #1 (permalink)
Member: 105625
Thanks Meter: 44
Question Problems with testpoint on A1000
I'm unable to get PC detect S Blank Rainbow.
Smart-Clip instructions are often unclear so can anyone answere these question by experience, not by what smart-clip site says:
1) Will it work if button 1+2 is pressed before connecting battery?
2) Will LED on phone light up when done correctly, or should it be unlit at all times if done correctly?
No matter what i do, LED will light up, and pressing button 1+2 makes no difference - nothing is detected. BUT, if i press 1+2 before connecting battery, LED does not light, and as soon as i release buttons, PC will detect "Flash Operating System Interface". If i press the buttons again, it will detect "Flash Interface". Where is the problem - usb-cable (pin 13-14 shorted), or testpoint connection problem?
How can i know that the usb cable is correct?
Old 05-07-2007, 20:46   #2 (permalink)
Member: 105625
Thanks Meter: 44
Can noone answere these questions?
Also, is it really necessary to click "Search" in Smartmoto BEFORE releasing testpoint?
Old 05-08-2007, 00:45   #3 (permalink)
Member: 105625
Thanks Meter: 44
Nevermind.. I got it unlocked now. But of course, not using the method described at smart-clip.com. I had to do this:
Connect testpoint
Press and hold a+b
Connect battery
Release a+b
Press and hold a+b again
Click search
The Following 4 Users Say Thank You to James_S For This Useful Post:
Old 05-08-2007, 09:35   #4 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
Connect
TP a to b
Attach BATT
Click Search and Continuously Press A B Button
When Got Detect with moto
Release TP.
thats my Tested Method.
bR
Old 05-08-2007, 09:59   #5 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,497
Here is tested and 100% working method.
  1. Disassemble the phone.
  2. Connect phone PCB to PC via Smart-Clip (phone > Forced boot mode cable > Smart-Clip > LPT cable > PC).
  3. Connect S-Card to PC USB port.
  4. Connect power supply to Smart-Clip.
  5. Launch SmartMoto.
  6. Choose "Smart-Clip USB port" in phone connection window.
  7. Connect TestPoint A to TestPoint B.
  8. Connect phone battery.
  9. Push Button 1 and Button 2 simultaneously.
  10. Press "Search" button in SmartMoto. Software should perform the following steps:
    • SmartMoto detects S-Card;
    • SmartMoto detects Smart-Clip;
    • SmartMoto detects the handset as "S Blank Neptune LTE", "S Blank"Paragon POG" or "S Blank Rainbow POG".
  11. Disconnect TestPoint.
  12. Log to bookmark "Unlock".
  13. Select a correct model from the scrolling list.
  14. Press "Unlock via TestPoint".
  15. Disconnect PCB after the process completed.
  16. Assemble the phone.
Please ensure that all steps are performed correctly strictly following the manual. Do not make too long pauses between each step.
Best Regards
GSMServer team
Old 09-14-2007, 17:26   #6 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
Is this passable to unlock A1000 with Magic TP
Old 09-15-2007, 08:36   #7 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ Miftahudin,
We recommend to use standard TP for unlock procedure.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 05-01-2008, 11:32   #8 (permalink)
Member: 134476
Thanks Meter: 14
@ James
Your method works perfectly, and we tried so many times all failed.
With your method 1 time, it worked great.
thanks agian
Old 05-01-2008, 11:37   #9 (permalink)
hrkgloballinks's Avatar
Member: 129536
Thanks Meter: 9
I have motorola E1000.am able to enter test mode but the phone is not connecting for flshing.Can anybody help me out.
Old 05-05-2008, 08:45   #10 (permalink)
Member: 229997
Thanks Meter: 636
@ hrkgloballinks,
Please explain what problem you have in more details.
In case if the set can not be recognized by PC/SmartMoto, ensure that the cable work properly and the connector is clean.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
problem with testpoint cable V-spec Matrix rev J.A.F. V-SPEC 2 03-28-2008 14:48
MTBox PRO problem with Testpoint DonaldDuck69 MT-BOX 6 08-21-2007 08:00
Myc-4 problem with testpoint neluturap SAGEM JTAG UNLOCKER 4 04-11-2006 12:47
Problems with testpoint! phone_abuser Sony Ericsson 0 08-31-2004 00:24
T180 - dead - problem with testpoint tozitom Motorola Old Legacy (EMMI) 0 04-08-2004 19:49
Page generated in 0.16969 seconds with 9 queries
