04-23-2008, 07:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | L7 problem i have problem in flashing L7 i got a set with boot loader version 0A.20. Sw VERSION R4517_G_08.C41ER I FLASH WITH THIS VERSION L7_R4517_G_08.C4.1ER_lp0003_full_flash.mfw L7_R4517_G_08.C4.37R_lp002F_full_flash.mfw THE PROBLEM IS SAME SET IS ON BLINKING PLZ GIVE ME SUGGESTION WHICH FILE I HAVE TO WRITE ON IT Last edited by Y2ksalman; 04-23-2008 at 08:01. |
04-23-2008, 08:04 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Y2ksalman, Please explain in more details what problem you have. Try to perform Repair PDS and after that Full Flash it with the R4517_G_08.C4.37R once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-23-2008, 08:38 | #3 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | i also do with repair pds still on blinking b4 i try to change imei i didn't check the sw version i also do repair pds at that time b4 repair pds 1st time its boot loder version was 0.92 after repair pds its comes a.20 |
04-23-2008, 09:06 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Y2ksalman, Show us log file, please. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-23-2008, 10:01 | #5 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | ohk here is the log now S-Card: --------- Smart-Clip dongle, v 2.07, assigned Smart-Clip: -------- Europe, initializing... OK Clip serial: ---, version: 4.07, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 3------- IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (2).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 2 of 2... 100% (53.5 Kb/sec) Flash completed! Turning phone off... io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 355573013049918 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (3).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Preparing... clip communication failed Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 355573013049918 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (4).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Writing flash section 7 of 7... 100% (52.3 Kb/sec) Flash completed! Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 355573013049918 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (5).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (31.2 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.3 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (44.4 Kb/sec) Flash completed! |
04-23-2008, 10:49 | #6 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 355573013049918 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (7).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone Writing flash section 1 of 1: security area... 100% (29.7 Kb/sec) Flash completed! Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... A.20 Boot prepare... failed Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.20 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W 5,W490,W510,Z3 Hardware IMEI: 355573013049918 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 355573013049918 (8).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (30.9 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.3 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing section1 done Flash completed! Applying IMEI patch, please wait (up to 2 minutes!)... OK IMEI patch successfull, set new IMEI with the "Write" button Writing new IMEI 35557301309876... OK Turning phone off... OK thanx a lot Mr Mr.Tinkertrain set is ohk now |
04-23-2008, 11:26 | #9 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | first prepare phone thne write this L7_boot_8[1].D.0 file your phone will be ok after this full flash with this file L7_R4513_G_08.B7.E0R_RB_lp0032_full_flash.mfw |
l7 problem | dee4dee | Motorola P2k | 1 | 11-07-2006 20:26 |
Help me about l7 problem | zicusa | Motorola P2k | 0 | 10-12-2006 14:52 |
L7 problems | SLVRL7 | Motorola P2k | 0 | 08-20-2006 17:57 |
L7 problem after unlock.... shows test mode screen... | Burnt Cobba | Smart-Clip | 11 | 06-08-2006 11:06 |
L7 problem | soki | Motorola P2k | 0 | 05-16-2006 06:39 |
