01-18-2005, 13:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Location: pandora's box Age: 45
Member: 44249 Status: Offline Thanks Meter: 2 | Smart-Clip dead after use of wrong polarity on power Adapter!!! 3 chips inside r melted...they r behinde the connector for power adapter, can somebody open the Clip and tell me what colors r 2 chips R1 and R2? -- Best regards, mayer |
01-18-2005, 13:15 | #2 (permalink) |
Insane Poster Join Date: May 2003
Member: 29063 Status: Offline Thanks Meter: 0 | You have ****n your clip- the clip is a fantastic product and it is the user ( ie you ) has made the mistake with the polarity. A bit like bolting the door after the horse has bolted. can you take a picture of the damaged chipos and i will look for you which is which- but i cannot think which are talking about . in all honesty i think that you will have to purchase a new one- but it is such an valuble product i would think that you would get your money back rather quickly especially with the new updates and supported phones. |
01-18-2005, 14:13 | #3 (permalink) |
Freak Poster Join Date: Oct 2002 Location: UK
Member: 16494 Status: Offline Thanks Meter: 6 | Just had a look a the pcb in my smart clip.....Smart Clip has reverse voltage protection built in. Looks like all you have done is burnt out the 2 x 1 ohm resistors and/or the reverse protection diode (probably gone short cct) at the power input. Any competent tech would be able to put that right for a few squids ...easy peasy ! EDIT: most certainly it's the two resistors (1 ohm) that u refer to that have burnt out if u only used a low current adaptor then diode is probably ok This IS part of the protection circuit !! |
01-18-2005, 19:27 | #5 (permalink) |
Member: 16494 Status: Offline Thanks Meter: 6 | Ooh dear I'm sure you can source 2 x 1 ohm 1/2 watt resistors locally !!! if not take them out of something else old m8 ........ ! (or a 0.5 ohm 1 watt will do) Edit: If diode faulty ...USE anything better than 200 PIV @ 1 AMP Last edited by Faxman; 01-18-2005 at 22:35. |
sagem my230x Dead after use Clip NEed Help | ExTeem-Unlocker | MT-BOX | 0 | 01-17-2009 15:07 |
Smart Clip How To Use | dhie2424 | Motorola Hardware Repair | 0 | 04-15-2008 08:16 |
R210 dead after using Warrior clip | rayback | Samsung Hardware Repair | 0 | 07-12-2006 18:00 |
T192 dead after use of test point. | Migeni | Motorola Old Legacy (EMMI) | 8 | 02-18-2003 19:17 |
Why some of V50 are dead after using Test Point? | osvaldas | Motorola Old Legacy (EMMI) | 1 | 09-15-2002 21:46 |
