02-24-2010, 05:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | smartclip not found help me? card is ok but when the connect the clip so show the clip not found i chang the lpt port or auto but still problem. so i clip updat so show reading clip inf..... auto searching clip..... looking for clip on smart adaptar....not found looking for clip at 0x378...ok clip serial :-1 firmware not found login... clip not registered... plz sir slove my problem urjent.thanks |
02-24-2010, 08:23 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ asif_ae, Please check these settings: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights After that run update procedure once again. If Smart-Clip would be detected by the update zone, save log file and send it to If it still can not be detected by the update zone, please write an e-mail to . In letter explain what problem you have, attach log file and specify serial number of the Smart-Clip, it suppose to be signed at the cover of the box. Best Regards GSMServer team |
Box not found! - Help Me.. | paxji | AlcaBull | 3 | 06-07-2009 19:41 |
3110 mmc not found*help me | gopalhot | Nokia Hardware & Hardware Repair | 2 | 12-04-2008 21:35 |
v804ss not found Help me unlocking step by step | maximusdecimus | UST Pro II | 23 | 08-25-2007 06:13 |
Help,Smartclip not FOUND | Ryuken | Smart-Clip | 13 | 03-13-2007 13:36 |
Firmware not found Help me | ligteltelecom | Smart-Clip | 4 | 08-22-2005 09:06 |
