Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 03-28-2012, 10:22   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
S-Card update probleme ?
hello to the team,
I can't update the S-Card pls ?
SN : XX9280910
Best Regards,
JAVA Good.
Old 03-28-2012, 10:49   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ JAVA Good,
If you're dealing with any difficulties during the update operation of Smart-Clip box, S-Card dongle or Smart Adaptor, following steps suppose to be performed:
  • Run update operation
  • Save log file in *.txt file format
  • Send log file along with the serial numbers to support[at]smart-clip.com
As soon as an e-mail will be received and all operations that are required for each case will be performed reply will be sent back to you e-mail.
Best Regards
GSMServer team
Old 03-28-2012, 11:04   #3 (permalink)
atiq022's Avatar
Member: 587405
Sonork: 100.1681610
Thanks Meter: 151
Problems with ActiveX client:
If you have problems running unsigned ActiveX, please open Explorer's menu Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt"
If you encounter problems during update make sure that:
Firewall on your computer (or your LAN) is configured properly or disabled
You have reliable internet connection
LPT port settings are set to EPP in BIOS
Your LPT cable works properly
You use a stable power supply with your clip (use power adapter)
Your IE version is not lower than v5.0
If you run update under WinXP, log in as Administrator or any other account with administrative rights
use internet explorer
The Following User Says Thank You to atiq022 For This Useful Post:
Old 03-30-2012, 12:36   #4 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 200
tks for all for your help,
but my key now is dead, from 2007 if I remember it's the 2th Time only I update it, and mybe unlock no more 5 phones with this crap Dongle, and now is dead for some peopel win some money,
I understand, but this is no good from the team
No Regard,
JAVA Good.
SIM card readers Ryu Hardware Equipments for GSM 7 10-30-2007 09:11
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.15585 seconds with 9 queries
