Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 05-30-2006, 08:39   #1 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
Motorola E770 unlock code?????
Hello,
unlock my phone with smart-clip do testpoint unlock done.
but still enter unlock code....
here is the logs
SmartMoto 1.20
Clip serial: 85******, version: 2.25, initializing... OK
Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.10
Reading bus width... OK
Reading flash id... Intel-28F256L18B (x2)
Phone group: E770,E1000,E1070, V3x,V975,V1050
Hardware IMEI: 35738*****
Security area saved to "S Blank Rainbow POG 357******.pds"
Unlocking phone... OK
any idea???
Regards
Majid
Old 05-30-2006, 08:41   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
Hello Gsm Lab,
most probably the phone wasn't unlocked.
Try to make Unlock Procedure again.
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 05-30-2006, 09:04   #3 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
ok i have try to unlock again
thanks
Old 05-30-2006, 11:38   #4 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
Hello, i have unlock again still same
enter unlock code:
Old 05-30-2006, 11:39   #5 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
check logs again
SmartMoto 1.20
Clip serial: 85*****, version: 2.25, initializing... OK
Searching for phone... no phone found
Hardware IMEI: 3573*******
Security area saved to "S Blank Rainbow POG 357387002197887 (1).pds"
Old 05-30-2006, 11:45   #6 (permalink)
YourPhone's Avatar
Member: 58075
Thanks Meter: 17
enter unlock code:
Enter unlock is user code try this no TP just read info
Old 05-30-2006, 14:23   #7 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
phone info not showing
Old 05-30-2006, 14:31   #8 (permalink)
seth_ro's Avatar
Member: 188359
Thanks Meter: 9
Doesn't anyone figure it could be a usercode or security code that the phone is asking for?
Power on the phone normally, connect to smart-clip and see if tells you the code.
Old 05-30-2006, 15:15   #9 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
i have enter all code 1234 ,,,0000 etc ....
but still same
Old 05-30-2006, 15:47   #10 (permalink)
YourPhone's Avatar
Member: 58075
Thanks Meter: 17
GOTO information top of the left column, then "read phone info" NO TP needed
@seth_ro yes I did at 11:45
Old 05-30-2006, 17:26   #11 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
connect my phone without any tp read phone info got error
here is the logs
SmartMoto 1.20
Searching for phone... found Motorola Phone (E770v), getting test interface... AT command error
Clip serial: 85****, version: 2.25, initializing... OK
Searching for phone... found Motorola Phone (E770v), getting test interface... clip communication failed
Old 05-30-2006, 17:31   #12 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
Searching for phone... found Motorola Phone (E770v), getting test interface... smart clip on/off then
Old 05-30-2006, 17:35   #13 (permalink)
seth_ro's Avatar
Member: 188359
Thanks Meter: 9
Hehehehe, just as I suspected.
You problem is this: the connection settings for the phone are set to "memory card" instead of "data/fax" and this is why you're getting that AT blah blah error when you search in smartmoto.
The exact same thing happened to me with a V3x.
I tried just about everything except for full flashing the phone.
Bottom line is you can't solve this except with a fullflash, via TP of course.
I know it *****, but I don't think there's another way.
Removing the card won't help...
Old 05-30-2006, 17:40   #14 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
check v3x
try to read phone info work fine reading all information
Model V3x
IMEI
User code
Security code 1234
Operation band
Firmware
Flex version
Language pack
Old 05-30-2006, 17:44   #15 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
Well, i have try to full flash my phone...
plzz tell me the E770 good file name in the boot-loader
i ahve download that ?
just like a v3 file OCR
thank's for the help
br
MOTOROLA E770 unlock done via testpoint. see report themobileshop Smart-Clip 0 12-21-2009 15:28
Motorola E770 Unlock and repair pds errors, plz help majid2 Smart-Clip 7 07-19-2006 19:10
e770 unlock code ???? Gsm Lab Motorola P2K (USB-Smart) 13 07-10-2006 12:39
motorola v66 unlock code starphone Phone Unlocking Codes & Maps 0 07-09-2002 19:45
motorola v66 unlock code? xiapunt Motorola P2k 0 06-18-2002 22:24
Page generated in 0.26892 seconds with 9 queries
