Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 04-25-2012, 23:55   #151 (permalink)
Member: 58263
Thanks Meter: 19
I have very strange problem with one Huawei G6603. Phone isn't locked, and with both sim card work the same: Accept call for both card, both card can only call 112, but can't call any other number. Even if I try to check call baring from menu, phone doesn't allow it and write SOS CALL ONLY! Can I flash or eeprom or reset eeprom, which was my first tought on this case?
Thank you for any help.
Old 04-25-2012, 23:56   #152 (permalink)
Member: 58263
Thanks Meter: 19
BTW, I can read it with smart clip and nothing strange I noticed...
Old 04-26-2012, 07:39   #153 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,859
@ neper,
Try to run Read Unlock Codes operation and post results after that.
Just in case, save Calibration backup before performing any operation.
Best Regards
GSMServer team
Old 05-07-2012, 18:33   #154 (permalink)
Temporary banned !!
Member: 71290
Sonork: 100.1645657
Thanks Meter: 105
please error R791
Originally Posted by GSM_Support View Post
Dear users,
SmartMoto becomes to be multi-brand MTK solution and now we are working under adding support of bunch of new brands. Unlock of specified below models wasn’t fully tested yet, so please create backup copies before performing any operation to the phone.
Unlock (and other actions) of MTK models
Direct Unlock option for not tested MTK based models, listed here, is temporary disabled. Such features are currently active for untested models:
Please post backups along with log files in this topic.
Phone models list:
  • Huawei: G5730, G5760, G6608, G6622, G7050, G7600, G5010, G5500, G3610, G6600 (MTS-635), G6300, G6620, G6608, G7010, G7210, G6603, G7206c, G20, G3500, G6700, G7007, G5630, G7010, G6610v, G6610, G7007, G6150, G3501, G3510, G7300, G7105
  • Vodafone: V545, V547i
  • Coral: 680
  • ZTE 120F, 231, 731, A136G, A139, A201, A205, A205+, A211, A215, A215+, A261FM, A292, A611+, A661, A861, F120, i628, i766, i799, N280, N281, N290, N295, R220, R221, R225, R230, R231, R236, R620, R630P, R791, S202, S212, G-S213, T202, X632, X670, X671, X730, X760, X761, X930, X960 (SFR-342), X990, X991
  • Fly: Q200, Q400, E130, E140, E145, Е147 TV, E146, Ezzy 3, ST230, E176, DS105, G1, DS160
  • Avvio: 505
  • Chat Phone: SN50, QS300
  • Message Phone: QS150, QS200
  • Azumi: m3
Tested in the topic models are marked RED.
Backups created from the phones based on CPU MT6235 with NAND flash memory type are most necessary. Also, please notice that backup copies suppose to be saved with the latest SmartMoto version (version 4.28 or higher).
Best Regards
GSMServer team
Unlock failed ZTE R791:
Thanks to Mr.Developer <[email protected]> for translation to Espanol!
SmartMoto 4.29
S-Card: //////////// Smart-Clip dongle, v 3.10, registrada con Smart-Clip: /////////// Europa, Inicializando... OK
RIM Virtual Serial Port v2 (COM17), provider - Research in Motion, drv. ver. 2.1.0.4 from 08/01/2007
Pulse y mantenga el boton de encendido
Cancelled
USB Serial Port (COM7), provider - FTDI, drv. ver. 2.6.0.0 from 21/10/2009
MCU: MT6253, HW rev. A.02, SW rev. A.00
Suelte el boton de encendido
Chequeo de la memoria exterior8 Mb
Arquitectura: NOR, Fabricante: Intel, Modelo: M18LR256B
Flash size - 32 Mb, TOP
Firmware size - 20 Mb, Filesystem size - 12 Mb
Firmware - ZTEMT53_09B_PCB01_GPRS_MT6253_S00.R791_V1_Z1_ES_A1 CF200
El IMEI de hardware no puede ser leido
IMEI de Software: 35275804051xxxx
Este modelo todavia no esta soportado
Old 05-08-2012, 08:19   #155 (permalink)
Member: 121052
Sonork: 100.107126
@ francoo,
Read phone backup from this handset and send it along with the log file to support[at]smart-clip.com
Alternatively upload backup copy (with the log file) to some file sharing web site and PM link for it to me.
Best Regards
GSMServer team
Old 05-09-2012, 17:36   #156 (permalink)
Member: 58263
Thanks Meter: 19
Huawei G6603
@ neper,
Try to run Direct Unlock operation and post results after that.
Best Regards
GSMServer team
I try that, but I get message something like: That model not supported yet...
Codes was readed without problem...
B.R.
Old 05-10-2012, 16:45   #157 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Vodafone 255 by ZTE supported?
Need pinout.
Old 05-11-2012, 07:17   #158 (permalink)
Member: 121052
Sonork: 100.107126
@ roberts,
Unlock of Vodafone 255 wasn't tested by our users, currently.
If you have this handset you can run Read Unlock Codes operation, according to the manual, and post results here.
It is recommended to read phone backup before performing any operation, just in case.
Pinouts and recommended drivers for the MTK based phone models available under the unlock manual.
Best Regards
GSMServer team
Old 05-11-2012, 07:35   #159 (permalink)
mubasharsoft's Avatar
Member: 1608878
Sonork: 100.1608233
Thanks Meter: 378
good update smart clip team thanks...........
Old 05-17-2012, 16:10   #160 (permalink)
Member: 1187105
Thanks Meter: 26
G7010 back-up
here is the link
G7010_flash backup.rar
Old 05-17-2012, 19:36   #161 (permalink)
Member: 58263
Thanks Meter: 19
huawei 6303
@ neper,
Best Regards
GSMServer team
I can read phone codes without problem!
B.R.
Old 05-22-2012, 12:39   #162 (permalink)
Member: 492293
Thanks Meter: 327
pls code for U1280
imei 355291032151413
Old 05-29-2012, 03:52   #163 (permalink)
Member: 391644
Thanks Meter: 22
G6600 Unlock Successfully via read code.
SmartMoto 4.29
S-Card: 50000000 Smart-Clip dongle, v 3.10, assigned Smart-Clip: 1000000 Europe, initializing... OK
Clip serial: 172864532, version: 5.03, initializing... OK
Searching for phone... no phone found
USB Serial Port (COM32), provider - FTDI, drv. ver. 1.0.2154.0 from 4/15/2004
MCU: MT6235, HW rev. C.00, SW rev. A.01
Release the Power ON button
Testing external RAM...32 Mb
Architecture: NAND, Manufacturer: Hynix, Chip model not detected [AD00A1-15]
Flash size - 128 Mb, Page size - 2048, Bad blocks - 1
Firmware size - 32 Mb, Filesystem size - 96 Mb
Firmware - BYD35_09A_PCB01_GPRS_MT6235B_S01.E5_2AV02V01_02
Hardware IMEI could not be read
Software IMEI: 3560000000038
Volume /dev/ffs1 mounted
Reading codes...OK
Software IMEI: 35000000008
Analyzing flash structure, please wait (up to 6 minutes!)...OK
"WX 356344043440538.wxbk" saved, 32.09 Mb
Software IMEI: 3563400000038
Reading codes...OK
Old 06-10-2012, 13:53   #164 (permalink)
Member: 193003
Thanks Meter: 46
ZTE -G N295 unlock problem
unlock or read code same pb
Z3X BOX Serial Port (COM13), provider - FTDI, drv. ver. 2.6.0.0 from 22/10/2009
MCU: MT6235, HW rev. A.04, SW rev. A.01
Architecture: NAND, Manufacturer: Hynix, Chip model not detected [AD0076-AD0076]
Flash size - 64 Mb, Page size - 512, Bad blocks - 0
Firmware size - 32 Mb, Filesystem size - 28 Mb
Firmware - ZTENJ35_GEMINI_10A_PCB01_GPRS_MT6235B_S01.EFS-EE-ORG-P107A20V1_0_5B03
driver start error
Not valid IMEI, operation cannot be performed
Old 06-15-2012, 12:30   #165 (permalink)
Member: 892974
Thanks Meter: 14
what cable to use on huawei g6600?? I tried v3 and se cable but not working. Can you explain steps taken please.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.25497 seconds with 10 queries
