V1050 how to bring back Boot loader 0.6.3.1 I just got here V1050 Vodafone w/ bootloader 0.6.3.1 appears after putting the battery. So, I just repair PDS. After the PDS repairing procedure, phone now show garbage screen with black and white colors. I flash the phone with V1050_R26LD_U_83.38.49I_lp0039_full_flash.mfw, but the result is the same garbage black and white screen. I also done testpoint procedure but the result is the same. How can I bring back the bootloader 0.6.3.1?:( |
anybody? how can I sort this problem?:( |
Is there any other sw that can repair this problem? Or is there anybody can share a full flash backup .mbk of this fone?:( |
@ Dj King, Please tell us what firmware version your phone originally had. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
@Mr Tinkertrain Thanks for the reply sir! The phone has an original firm version of R26LD_U_83.38.49I_LP0039. |
@ Dj King, The phone was flashed with the highest available firmware version. Try to performed Repair PDS and Full Flash procedures once again. Save log file and post it here, just don't forget to hide your serial number. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Here's the second log file and same result. I flash with other version. Still no luck. Switching to flash mode... OK Reading phone boot version... 5.F1 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 IMEI OTP status: locked Security area saved to "PDS for S Flash Rainbow POG (6).mbk" Login request... OK Writing flash section 4 of 4... 100% (10.5 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 2 of 2... 100% (120 Kb/sec) Turning phone off... OK Flash completed! Any ideas? I think repair PDS on smartmoto for this model don't work. Cannot fix or repair the Blue and white screen after putting the battery on the phone.:( |
@ Dj King, Full Flash the phone with the same firmware version like it had or higher one. R26LD_U_83.38.49I is the highest available firmware version, Full Flash the phone with it. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
I almost try 5 times repairing PDA and flashing with R26LD_U_83.38.49I firm. With and w/out testpoint. But the phone always garbage blue and white screen appears after putting the battery to fone instead of bootloader 0.6.3.1. |
@ Dj King, As the handset had boot version 6.31 it supposed to be unlocked via Remove RSA procedure. What boot version it has at this moment? http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
There is no boot version as I said before because when I put battery to phone, there is no more bootversion displayed on the screen. It Just displays only garbage blue and white colors. Before I repair the phone with smartmoto, when I put the battery to phone, it quickly displays Bootversion 06.31 and it's firm version on the phone's lcd. But, when I repair PDS with Smartmoto, the displayed bootversion 06.31 on the lcd has disappeared and became all went to garbage blue and white colors on the screen. |
@ @ Dj King, Try to perform Remove RSA procedure, manual can be found here. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
@ Dj King, Now try to perform Repair PDS and Full Flash procedures once again. In case if the problem will be still the same, then most probably that the phone has some hardware malfunction. http://www.gsmserver.com/img/sc_userbar.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
