02-21-2005, 19:02 | #1 (permalink) |
Freak Poster Join Date: May 2004
Member: 64341 Status: Offline Thanks Meter: 1 | smart clip not establishing lpt connection with computer secondly i tried to remove D8 but the clip would not even power on any longer, so in frustration i replace d8 and came her for a possible solution. pls i need someone who has encounterd this problem before to help with solution or someone will a richer understanding of the schematic to give possible suggestions as i am will to take the any risk. regards |
02-22-2005, 14:13 | #2 (permalink) | |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,345 | Quote:
BR Smart-Clip Team | |
02-25-2005, 01:24 | #3 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | Quote:
I've the same problem, I have read the rules of the set-up steps, but I haven't a clue how to get into my BIOS on my PC . What advice would you give ? Thanx in advance. | |
02-25-2005, 02:42 | #4 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: Portugal.Chelas Age: 39
Member: 12966 Status: Offline Thanks Meter: 133 | Quote:
just start the pc and you see on dos mode some fing like this setup??? = to keyboard keys esc or f1 or f2 etc just press and go to bios must of home pc use esc for bios on laptop toshiba is esc dell is f12 compaq f2 fujitsu is f10 | |
02-26-2005, 12:36 | #5 (permalink) | |
Junior Member Join Date: Feb 2005 Age: 45
Member: 120099 Status: Offline Thanks Meter: 0 | Quote:
BR. | |
02-26-2005, 22:19 | #8 (permalink) | |
Member: 100436 Status: Offline Thanks Meter: 57 | Hi, I have the LPT problem sorted now. BUT I have a new problem see below. I have followed all the steps: Quote:
EDIT I'm using the USB to power the Clip, is that ok ? | |
02-26-2005, 22:45 | #9 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.thefonedoc.com Age: 55
Member: 84155 Status: Offline Thanks Meter: 8 | NO! Thats your problem The USB port on the Smart Clip is for unlocking/flashing You need to power it using an external 9v power supply uint which plugs in where your battery normally goes. |
02-26-2005, 22:52 | #10 (permalink) |
Member: 100436 Status: Offline Thanks Meter: 57 | But it says: SMART-CLIP UPGRADE PROCEDURE 1. Connect Smart-Clip to PC using LPT cable 2. Power Smart-Clip ON (warning: don't use battery!) 3. Go to our Upgrade Zone 4. Upgrade Zone uses ActiveX element, answer "Yes" to install and run it 5. Press "Connect" 6. Press "Update" if your version is out of date 7. Power Smart-Clip OFF 8. Disconnect LPT cable ie don't use battey in the PDF manual ? EDIT Oh power supply, bollix where will I get one of those Cheers irishclips |
02-26-2005, 23:01 | #11 (permalink) |
Member: 84155 Status: Offline Thanks Meter: 8 | Yeah....power supply...as the battery can give problems if there is not enough power etc in it and can damage the clip PM'd u details on power supply |
My smart-clip not connect | yoyor | Smart-Clip | 1 | 10-12-2009 13:53 |
PCI LPT port - Smart Clip not FOUND !! | zakiyyboss | Smart-Clip | 1 | 08-05-2009 07:10 |
smart clip not connected properly | 2ct | Smart-Clip | 5 | 10-04-2008 07:42 |
about smart-clip not connect | prem2007 | Smart-Clip | 3 | 12-17-2007 13:18 |
about smart-clip not connect | prem2007 | Smart-Clip | 1 | 12-15-2007 09:29 |
