03-30-2011, 21:49 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | v975 boot 6.1.2 dead after remove rsa |
03-31-2011, 07:17 | #2 (permalink) | |||
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ i-touch, Quote:
Best Regards GSMServer team | |||
The Following User Says Thank You to GSM_Support For This Useful Post: |
03-31-2011, 10:11 | #3 (permalink) | ||||
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | Quote:
i don't save the log. if the smartmoto automaticly save it; so when can i find it? Quote:
0.5.f.1 sw version: r245_u_82.31.56i battery ok transfer mode: serial rs-232 Quote:
i try to flash with R245_U_82.31.68I_lp002C_full_flash.mfw . the phone flash completed but it show the some screen as flashed with r245_u_82.31.56i the only log that i saved is like this Quote:
03-31-2011, 10:49 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ i-touch, Log files doesn't get saved automatically by software. Connect the phone via TestPoint after that run Repair PDS procedure and Full Flash it once again. Best Regards GSMServer team |
03-31-2011, 11:07 | #5 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | already make this befor posting. 1-is it normal that the boot version is changed from 6.1... to 0.5.1. 2-why even i flash the phone with other firmware version it show always in screen the same firmware (r245_u_82.31.56i ) |
03-31-2011, 12:12 | #6 (permalink) | ||
Try to perform Repair PDS procedure once again and after that Full Flash the set with the same firmware version like it initially had. Also, please tell us what was signed on the screen of the phone after Remove RSA procedure. Best Regards GSMServer team | ||
03-31-2011, 12:54 | #7 (permalink) | |
03-31-2011, 15:52 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ i-touch, Did you try to perform Repair PDS procedure and full flash the phone with the r245_u_82.31.56i after that? Provide us with log file, please. Don't forget to erase serial numbers. Best Regards GSMServer team |
03-31-2011, 16:02 | #9 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | i am trying many flash file but no luck. this is the security back-up if you can extract any information about frw version and boot version or any other help. thinks http://rapidshare.com/files/45527369...6000268212.rar |
03-31-2011, 16:53 | #11 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | R245_U_82.31.56I_lp0039_full_flash.mfw R245_U_82.31.56I_A_lp004D_full_flash.mfw R245_U_82.31.68I_lp002C_full_flash(1).mfw R245_U_82.32.30I_H_lp0033_full_flash.mfw R24_U_80.3F.A5I_lp0039_full_flash.mfw |
03-31-2011, 18:03 | #12 (permalink) | |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | After many trying many time flash and repair pds. Now the phone not goes into flash mode AFTER FLASH OR REPAIR but it schow only error on screen : 0xbad Quote:
04-03-2011, 15:20 | #13 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | i think there is no ways to revive this phone. plz smart team added autosave log operation to software like other teams software. so in case of wrong worck we can return to the first log file saved. thinks |
04-22-2011, 08:39 | #15 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ i-touch, Perform following operations: 1. Connect the phone via TestPoint 2. Run Repair PDS operation (don't power on the set after that) 3. Full Flash the phone with r245_u_82.31.56i After these procedures will be completed, post log file here. Best Regards GSMServer team |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
