V3I (iTunes) DEAD :( , Help!!! Thanks to Mr.Developer <[email protected]> for translation to Espanol! SmartMoto 1.22 Número de serie del clip: xxxxxxxx, versión: 2.26, Inicializando... OK Buscando el teléfono... Encontrado S Blank Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Buscando el teléfono... Encontrado S Blank Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Leyendo versión del boot del teléfono... 3.00 Leyendo la id de la flash... 0xFFFF-0xFFFF Grupo de teléfonos: V235,V360,V360v,V3i,V3r,L7,L7v Leyendo OTP... Error B8 Atención: Lectura de OTP fallida Buscando el teléfono... No se encontro el teléfono Unlock for testpoint and after error. RSD flashing error, any solution? Thanks for all. Sorry mi bad english. |
i hv been waiting for a month n still cant solved my v3i r47a ,just transferring 2 songs by bluetooth n its dead so pls GSM SUPPORT pls hurry up with this v3i problems for unlocking n repairing pds |
@ coyote14, Leyendo la id de la flash... 0xFFFF-0xFFFF means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
I have new problem: SmartMoto 1.22 Clip serial: xxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Boot prepare... failed and display PHONE CODE SIG ERROR: ITS BAD FLASHING FOR R479_G_08.B4.34R MI PHONE IS V3I ITUNES NEED FLASH R47A_G_08.D8.35R, HOW REMOVE FIRST SOFTWARE. |
@ coyote14, Update your Smart-Moto and check this link http://forum.gsmhosting.com/vbb/showthread.php?t=306268 Thank You! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V3I (iTunes) DEAD phone repair PDS test OK! with smart-moto 1.23 dead phone is power on. |
SmartMoto 1.23 Clip serial: ********, version: 2.26, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, ST-M58LR128FT Phone group: V235,V360,V360v,V3i,V3r,L7,L7v Hardware IMEI: 359414002548113 Security area saved to "S Blank Neptune LTE2 359414002548113.pds" Login request... OK Writing section0 done Writing section1 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... OK Writing section0 done Please write a corresponding Full_flash file to phone to accomplish repair Writing section0 boot done Writing section1 done Flash completed! |
smart-clip repair V3i (R47A) PDS first in world! |
Hello, i have new problem, not repair psd for this error in TestPoint: SmartMoto 1.23 Número de serie del clip: XXXXXXXX, versión: 2.26, Inicializando... OK Buscando el teléfono... Encontrado S Flash Neptune LTE2, Entrando en interfaz de test... Interfaz no encontrada Entrando en modo flash... OK Leyendo versión del boot del teléfono... A.30 Boot preparado... Fallido I have problen for bad flashing, this V3i is Itunes(R47A_G_08.D8.35R), and bad flashing for client (R479_G_08.B4.34R) how erasing full v3i and flashing latest vercion R47A_G_08.D8.35R. Sorry my bad english, and thanks for all. |
repair PDS for R47A and reflash with a R47A flash |
Repair PSD=OK,Flashing=OK Result=PHONE CODE SIG ERROR: :mad: :mad: :mad: :mad: |
Did you select a correct version from SmartMoto list, before performing Repair PDS procedure? That is important. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
please report any advance! Thanks! |
@ k2k00, please tell us what firmware version the phone originally had? What phone model you have selected in repair PDS list? Also please tell us with what firmware version you have flashed it. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Hi I have a same problem. I make a mistake to flash v3i itunes (r47a) with R479 flash ! Boot 0A52 Now I repair PDS (R47A) and flash it with FF R47A.... and the phone is always in flash mode !!! Anybody help me please ?? Many thanks |
