09-23-2008, 14:17 | #1 (permalink) |
Junior Member Join Date: Jan 2002 Location: Bangkok
Member: 9000 Status: Offline Thanks Meter: 2 | V3i show Searching for phone... found S Flash Neptune LTE2 only first repair pds then full flash then imei repair firmware flash err 09 pls advice |
09-24-2008, 11:05 | #3 (permalink) |
Member: 9000 Status: Offline Thanks Meter: 2 | SmartMoto 3.16 S-Card: xxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxx Europe, initializing... OK Clip serial: xxxx, version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 352503019058475 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 352503019058475 (19).mbk" Login request... OK Writing flash section 2 of 2... 100% (28 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (16.5 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (65.4 Kb/sec) Flash completed! Preparing... error A9 |
09-24-2008, 11:15 | #4 (permalink) |
Member: 9000 Status: Offline Thanks Meter: 2 | I dont know orriginal Firmware 1.repair pds 2.flash V3i_R479_G_08.B4.8BR_lp0021_full_flash.mfw 3.imei repair firmware patch shoe errror A9 4.Im dont detach cable form phone Pls Adv....****S...... First time v3i is ok then now shoe S Blank Neptune LTE2 No display lcd |
09-24-2008, 12:18 | #5 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What has initially happened to this phone and why is it got detected as "S Blank Neptune LTE2"? Did you connect it with TestPoint? Best Regards GSMServer team |
09-25-2008, 15:55 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try powering it in boot mode and then flash again. If it still gets detected as S Blank, then it may have a hw problem. Best Regards GSMServer team |
S Flash Neptune LTE2 driver? | robsloo | Smart-Clip | 3 | 04-23-2008 12:17 |
S Flash Neptune LTE2 driver? | robsloo | Smart-Clip | 1 | 06-11-2007 07:52 |
Searching for phone... no phone found | aukonline | Smart-Clip | 4 | 01-03-2007 13:36 |
S Flash Neptune LTE2 for RSD lite | avroy7 | Motorola P2k | 1 | 07-10-2006 16:13 |
Searching for phone or Turn on the phone...??? | SicilianBoy | NSPRO | 5 | 01-28-2006 21:09 |
