v3r dead after unlock (for GSMServer team attentions) I have one pcs and I want to unlock it but after I flash the phone with v3 bootloader and after I unlock this phone via test point choiseing v3i phone. After that my phone is dead. Thanks in advance |
Well clearly the problem is your bootloader. You need to try to write a correct bootloader back to the phone to have it work. Since the V3 bootloader is actually designed for a different chipset, it might have overwritten other regions though. |
1 Attachment(s) Quote:
if does not works pls pm me |
SmartMoto 1.19 Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST-M30L0R8000B0 Reading flash id/2... OK, none Phone group: V360,V360v,V3i,L7,L7v Hardware IMEI: 358025000874219 Security area saved to "S Blank Neptune LTE2 358025000874219 (3).pds" Error: file flash data (48 Mb) does not suite phone memory |
why did you flash the bootloader?, there is no need to if you are just unlocking it via testpoint. you now need to flash v3r bootloader. br |
I know, I made a mistake .... I don't have a v3r bootloader to flash the phone... please help me with this.Thanks |
I think you need a living V3r :D |
