V3r unlocking problem Hello sir, I have having problem in v3r unlocking. Here is the log... SmartMoto 3.16 S-Card: ******* Smart-Clip dongle, v 2.10, assigned Smart-Clip: ******** Europe, initializing... OK Clip serial: *******, version: 4.08, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.52 Boot version 0xA52 is not supported for model 'V3r,V3v' |
@ sameer918, Boot version 0A.52 can be unlocked via TestPoint, only. Check this link for the detailed manual, please. http://www.gsmserver.com/img/sc_userbar_1.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The correct procedure to unlock your V3r with boot version 0A.52 is something like this mate... Disassemble phone Put TP wire on correct tp as you will see in motorola TP pics Plug usb cable to smartclip and connect cable to phone connect TP to ground Attach fully charged battery or 3.6 volts rps to phone Open smartmoto and select model Click search Click unlock.. Goodluck... |
Thanx a lot .... I will try. But i flash v3r with scout without test point,after flashing it locked...so can i unlock it with scout without testpoint??? |
@ sameer918, Quote:
It can be unlocked by the Smart-Clip, unfortunatey unlock procedure for this boot version supported via TP, only. http://www.gsmserver.com/img/sc_userbar_1.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Thanx sir...I unlock v3r with test point in smart clip. One more question... U r saying that "More likely that the phone was flashed with the locked firmware version and option "Set Subsidy code to..." wasn't picked up. Due this reason the phone is locked now."....... Can i download "Unlock Firmware" from bootloader.com?? So i flash with this file and Phone get not locked...Thanx |
@ sameer918, Quote:
Thanx a lot sir...So nice of u....Always helpful for all members. |
