Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 12-04-2008, 07:58   #1 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
V3r unlocking problem
Hello sir, I have having problem in v3r unlocking. Here is the log...
SmartMoto 3.16
S-Card: ******* Smart-Clip dongle, v 2.10, assigned Smart-Clip: ******** Europe, initializing... OK
Clip serial: *******, version: 4.08, initializing... OK
Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... A.52
Boot version 0xA52 is not supported for model 'V3r,V3v'
Old 12-04-2008, 08:05   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 623
@ sameer918,
Boot version 0A.52 can be unlocked via TestPoint, only.
Check this link for the detailed manual, please.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smar*********er.com
Old 12-04-2008, 08:19   #3 (permalink)
rontekgsm's Avatar
Member: 392166
Thanks Meter: 55
The correct procedure to unlock your V3r with boot version 0A.52 is something like this mate...
Disassemble phone
Put TP wire on correct tp as you will see in motorola TP pics
Plug usb cable to smartclip and connect cable to phone
connect TP to ground
Attach fully charged battery or 3.6 volts rps to phone
Open smartmoto and select model
Click search
Click unlock..
Goodluck...
Old 12-04-2008, 15:28   #4 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Thanx a lot .... I will try. But i flash v3r with scout without test point,after flashing it locked...so can i unlock it with scout without testpoint???
Old 12-04-2008, 15:39   #5 (permalink)
Member: 229997
Thanks Meter: 623
@ sameer918,
More likely that the phone was flashed with the locked firmware version and option "Set Subsidy code to..." wasn't picked up. Due this reason the phone is locked now.
SCout is powerfull multiflasher software. It can not unlock any phone.
It can be unlocked by the Smart-Clip, unfortunatey unlock procedure for this boot version supported via TP, only.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post:
Old 12-04-2008, 16:32   #6 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Thanx sir...I unlock v3r with test point in smart clip. One more question... U r saying that "More likely that the phone was flashed with the locked firmware version and option "Set Subsidy code to..." wasn't picked up. Due this reason the phone is locked now."....... Can i download "Unlock Firmware" from bootloader.com?? So i flash with this file and Phone get not locked...Thanx
Old 12-05-2008, 07:30   #7 (permalink)
Member: 229997
Thanks Meter: 623
@ sameer918,
The phone can not be unlocked by the flash file.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 12-05-2008, 09:21   #8 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Thanx a lot sir...So nice of u....Always helpful for all members.
V3r unlock problem, plz help! Saff Motorola Hardware Repair 6 06-02-2007 07:01
v3r unlock probleme riahi23 Ultima Box Light 2 04-16-2007 02:22
moto v3r unlock problem mamnb Motorola P2k 4 01-12-2007 07:57
V3r unlock problem sopiste Motorola P2k 2 12-03-2006 19:02
V3r unlock problem NPL2 Smart-Clip 1 09-02-2006 08:21
Page generated in 0.31835 seconds with 8 queries
