v3re dead after connect TP Please help, i have the problem, after connect TP box still ask TP , i disconnected it and connect again , now the phone cannot prepare again and is in blank mode, i tried to revival but i got flashing problem, when i try to set the flasher filewhich i have been use it , i got File stream error , my account to download the new one is expired please help SmartMoto 3.18 S-Card: 01111111111111 Smart-Clip dongle, v 2.10, assigned Smart-Clip: /////////////////// Europe, initializing... OK Clip serial: ///////////////// version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK File stream error ("C:\Program Files\GsmServer\SmartMoto\flash files\V3re R3442A_G_0E.43.08R_lp002E_full_flash.mfw") |
repair pds then flash... |
check cable & power suply...................thanks |
is it damage.... 4.00 boot mean damage hw chek the capaster where you connect tp and resold it if its damage try and post reply |
Please ensure the TP zone is clean and the mainboard doesn't have any short circuit. (Help is unable) B.R., kashi4gul |
if i want to reflash i got this error File stream error , and i have been using this file, is that even the downloaded file expire after one month?, |
The thing is that you are dealing with hw damage. Flashing will not solve the issue. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
how to solve this problem, can u view the smart log and tell me what to do, i can say that the phone died during prepration mode |
@ MGT SOFTWARE, Check the PCB of the phone for any short circuit, because boot version get read as 4.00 in case if the phone has some hardware malfunction, usually. http://www.gsmserver.com/img/sc_userbar_1.png Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
No solution for that problm at the time... usually bad test poin .... sorry br |
I am solve this problem.. hwo like solve this problem send me photo phone hardware and i help you |
There can not be a universal solution for this issue. All depends on the reason of the failure. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
this is a HW problem |
