V6 can't unlock communication failed please check motorola v6 unlocking via tp v2, when connected by tp instead of continuing smartclip communication failed... please check this bugs... http://i120.photobucket.com/albums/o...untitled-1.jpg br, mawxep03 |
@ mawxep03, Please tell us what power supply are you using with the Smart-Clip. What output value it has? Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
i tried 9v - 12v still the same... when making testpoint the box itself power off., the phone has no problem working 100%. |
if vibra is removable then remove it and try again it must be power supply problem or lower than the power requirement... |
@ mawxep03, Quote:
Please ensure that the power supply provides stable output, display disconnected and perform unlock procedure once again. If some error appears, please post log file, without serial numbers, here. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
