02-20-2009, 10:47 | #2 (permalink) |
Registered User Join Date: Oct 2007
Member: 617315 Status: Offline Sonork: Skopje Nord Macedonia Thanks Meter: 22 | can you GSM Support just tell me is it posible and how(if it is posible)? becasue I'm new with this box and I have one urgent piece for unlock |
02-20-2009, 11:40 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Unlock option for this model is not supported. You can flash it with SCout only ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
02-27-2009, 03:46 | #5 (permalink) |
Junior Member Join Date: Jan 2009
Member: 947541 Status: Offline Thanks Meter: 0 | MOTOROLA UNLOCK FREE Without BOX only USB Hi friends You know its very easy to unlock any Moto V3 to V3xx Etc Just in a minute ok im sharing here my experiance (but keep in mind it can work for u as for me 10000% but u have to go in a right way) 1.Install p2k commader (for you link is here) http://s5vi.vxxxstuff.com/ its a simple software as u know for exploring al moto Phone First STEP :Important is You have to install Only p2k Driver (its in directory of installed p2k) for you moto Modem otherwise it will not work If u can see in your device manager there is Motorola USb modem installed by Original Driver of Moto so Update it with p2k commader Driver. Now Time to UNLOCK Open P2k Commander Go to OPTIONS Click on P2k/P2k05 Down P2K tunning 'select Safe Slow (if u got any error just try to change setting When Ru again Before Connect ur phone) Click on USE P2K Command Override... (if u have V3xx These above setting if not work for u to detect your phone try keep changing defferent Settings Sure it will work NOW Click OK Connect Your Phone and Install P2k Driver (If ask again) On Down Window U Should see Phone connected (if not means Phone not detected or Driver is not P2k) If this Success then on Mian Window (any Right of Left Doesnt matter ) Select " /a P2K Phone System |"It will Start your Phone Data reading and Show u on Window UP (mostly here Poeples have problem or Error because of wrong setting in OPTIONS So Use your brian i know u can do it) it will show u /a (Directory of Your Moto) No need to open it in P2k Commader you can see SEEMS on top before OPTIONS Click on SEEMS and Discover Numbers Click on SEEMS and FUNCTIONS (click on it you will see all option of Moto) Now here is ur moto Locked in Some option So NOW carefully Find and Check/Uncheck Option bellow LOCKS THERE FEATURES Call barrinf Etccc...... Uncheck 00 SIMCARD NOT REQUIRED FOR PHONE ACCESS...... Uncheck Thats ITTTTTTT on Right hand Click on WRITE SEEMS (Dont Forget Important) Now Close Function and restart Your Phone From Main Window of P2k Commader u can see on right hand SO YOUR PHONE WILL BE UNLOCKED @Free This work for me on many Moto Last time on V3xx Please if its work for u Thank Boolna Yaar ok ANY Problem Just Inform me with your logs or Pic i will help u.. BEST OF LUCK Asif |
V8 unlock when will be support ? | smootny | Smart-Clip | 25 | 09-06-2010 13:14 |
v8 unlocking possible by Tp | mccm | Smart-Clip | 5 | 02-07-2008 08:21 |
Mayday. . . . Motorola.v8 Unlock | feng19890426 | Motorola P2k | 0 | 10-26-2007 09:18 |
Motorola SLVR V8 unlock!!!! | zeozea | Smart-Clip | 1 | 01-31-2006 19:57 |
Philips , Genie DB veriosn TCD898/V8 unlock??? | --==Dixon==-- | Philips | 5 | 09-24-2002 17:55 |
